Idle rattle noise ?
Old Feb 13, 2023 | 01:58 PM
91355evo9's Avatar
Idle rattle noise ?
LINK:
can you hear it? I have put about 700 miles since the full 60k service.
I dont recall the noise prior.
Thoughts?
Old Feb 13, 2023 | 02:08 PM
RallySport9's Avatar
something is definitely loose. Not any major component tho It even sounds like it could be a bolt or something bouncing around on the subframe, check timing/cam cover bolts any shields..
Old Feb 13, 2023 | 02:25 PM
91355evo9's Avatar
Perfect, will do. I initially thought bolt, but don't see it.
I talked to the shop, they said Wed 9am, please bring it in.
Appreciate the quick reply
Old Feb 13, 2023 | 04:30 PM
https://www.evolutionm.net/forums/ev...l#post11966007
Also check out this members thread, maybe you guys can communicate as the rattle seems to be coming from the same place? Id definitely return to the shop where it was serviced yea.
Old Feb 13, 2023 | 05:36 PM
91355evo9's Avatar
I literally saw this thread,after I made mine.
I will post back wednesday and close the loop
Old Feb 13, 2023 | 11:26 PM
ViciousLSD's Avatar
sounds like a loose hose clamp dangling around a pipe or a bolt that backed out (check the alternator assembly bolts)
redrocket03
18
Feb 25, 2012 01:15 PM
rmrEVO
11
May 23, 2011 09:18 PM
EndlessRed
May 17, 2009 07:24 PM
skold
May 27, 2008 09:58 AM
flip_EVO
May 18, 2007 10:04 PM
