Walboro Whine Issue on Evo VIII
Old Apr 12, 2023 | 03:28 PM
brokenevoviii's Avatar
5 Year Member
so the evo started making a new noise today, and i've been reading conflicting things.
I put my 255 in the car mid-February, and it whined from the get-go but not all that noticeable.
today, we're seeing the warmest day since I've put it in (80°F) and after my usual commute to school (25-30mi) the pump is s c r e a m i n g [video attached]
some posts say when it's warmer out, this happens and it's completely normal. other peoples wally's whined this loud from the get-go; some not at all, and live in warmer places than I do.
AFR's are fine, no lean spots when cruising or on boost when I was on my way home.
ANY input or help is appreciated, will baby car and stay out of boost until I can properly sort it (class tomorrow but off for a few days afterwards)
mods:
tuned on SD
drop in filter
evo 9 BOV
MBC @ 22psi
high flow cat/invidia catback
wally 255
File Type: mov
Old Apr 13, 2023 | 01:47 PM
kyoo's Avatar
i personally couldn't stand the walboro whine
Old Apr 17, 2023 | 11:51 AM
alleggerita's Avatar
Installed Deatschwerks fuel pump after the Walbro ... much quieter ... never looked back.
Old Apr 17, 2023 | 11:55 AM
kyoo's Avatar
same, been running the dw300, including on e85 with no issues.
Old Apr 17, 2023 | 02:58 PM
CurseDSM's Avatar
Sounds normal to me just be thankful you don't have dual 525s in the car. How much fuel in the car that will make a difference.
Old Apr 18, 2023 | 07:17 AM
mr.Freddy's Avatar
The thing I've learned is that if you want you fuel pump to live forever don't ever go less than a quarter tank of gas
Old Apr 22, 2023 | 07:58 PM
5 Year Member
UPDATE:
car can't hit boost without leaning out and it cranks hella long before it decides to start. new pump coming from a more reputable source.
Old Apr 23, 2023 | 12:32 AM
Fireescape's Avatar
I've had two genuine Walbro 460 fail within a week of each other, one where the pressure valve (spring-loaded ball bearing) jammed open, letting most of the fuel out the valve, and a brand new one where the magnets on the motor came off and were pulverise by the impeller. Luckily enough I always test new fuel pumps before installing them because the second one would've destroyed my engine if it had been installed in the car, and I recommend to anyone who will listen that they do the same, test them before you install them. Made a quick video about it which is on my YouTube channel.
Old Apr 26, 2023 | 03:57 AM
blackoutVIII's Avatar
I have had mine for over 10 years and it whines. It's fine!!
mrbonilla
Oct 27, 2016 06:29 PM
DONNOD
Jun 1, 2016 02:20 PM
RocketDive
Jan 16, 2012 11:35 AM
AhmadHasib
Aug 11, 2007 07:48 PM
chobits
Oct 11, 2005 07:51 AM
