Evo 9 oil cooler in evo 8
Old Oct 30, 2023 | 08:46 AM
krys88's Avatar
Does evo 9 oil cooler fit evo 8 and evo 8 lines??
Old Oct 30, 2023 | 09:28 AM
Ayoustin's Avatar
Different part numbers are listed for both but there shouldn't be any incompatibilities between them, at least there's none that I'm aware of.
Old Oct 30, 2023 | 09:32 AM
Kevin.'s Avatar
Different part numbers for the coolers, same for the lines. Eyebolts are different part numbers. I've compared them before and it looks like 9 has larger openings on the eye bolts.
eye bolt numbers
1225A006 vs MR464562
Old Oct 30, 2023 | 10:28 AM
krys88's Avatar
eye bolt numbers
Thanks a lot for help. So the eyebolts would need to be changed with the evo 9 cooler? How about bracket, can I use evo 8 bracket with evo 9 cooler? The evo 9 cooler is wider.
Old Oct 30, 2023 | 11:02 AM
RallySport9's Avatar
I swapped a 9 oil cooler as an upgrade on my 8 rs. Everything from the 8 fit onto the 9. Lines and everything. Never inspected them close up, all I know is it fits and functions. I dont know about the bracket because I used a 9 bracket too..
Old Oct 30, 2023 | 12:16 PM
Kevin.'s Avatar
I might have a picture comparing eye bolts, let me check.
I've replaced an 8 oil cooler in the past and most recently removed and reinstalled one. I bought used lines and bolts that came off a 9, that's how I noticed. Also swapped over to a 9 front bumper with the 9 oil cooler duct. I didn't know the 9 was different dimensions.
Old Oct 30, 2023 | 12:43 PM
krys88's Avatar
That's exactly what I am trying to do, I want to do upgrade cooler to evo 9 on my evo 8. I also has an option to buy maperformance setrab cooler but I was reading that people has a problems with lines leaking on them so I dont know what to do. Both of them are the same price around 450$
Old Oct 30, 2023 | 01:46 PM
Kevin.'s Avatar
OE oil coolers aren't cheap either
Old Oct 30, 2023 | 01:54 PM
ViciousLSD's Avatar
I dont have leaks with 1st & 2nd MAP Setrab but I made my own lines
Old Oct 30, 2023 | 02:39 PM
krys88's Avatar
Yea oem is 450 and setrab is 450. Is setrab better than oem?
Old Oct 30, 2023 | 02:41 PM
krys88's Avatar
How about oil pressure is it the same as on oem cooler? Also some people saying that in colder days oil is too cold with setrab I dont know if thats true
Old Oct 30, 2023 | 02:57 PM
ViciousLSD's Avatar
I dont know, I got the IE pan/pressure gauge around the same time. I doubt these oil coolers affect oil pressure though
Old Oct 30, 2023 | 03:07 PM
krys88's Avatar
Ok thanks for help, I think I will try it. I have a 1/2 filled block so maybe a little extra oil cooling might be needed. The worst case scenario I can cover half radiator in colder days or something
Old Oct 30, 2023 | 07:37 PM
krys88's Avatar
Hey one last question. I live in Illinois, I dont drive the car when snow is out but I still drive it in the fall when outside temp. can be as low as 30F. So basically the temperatures that the car see are 30F lowest and 85 highest in summer. Will map setrab cooler over cool the oil? Maybe I should really stick with evo 9 unit. I was reading somewhere that some people can't reach operating temp. with setrab cooler. The evo is fully build engine with 6870 turbo and I drive it on the street only, no track. I was using oem evo 8 cooler for the last 6 years but now I have a hole and it is leaking so I need to change it. Thanks!
Old Oct 31, 2023 | 07:23 AM
ViciousLSD's Avatar
I read the same ... i think that depends on where oil temp is measured and how much cold air the sensor gets. I dont have an oil temp gauge but as long as my oil pressure is reading about the same range before driving hard then I'm not too concerned
boostx
Sep 18, 2014 09:45 AM
94AWDcoupe
Oct 23, 2013 12:34 AM
EVOEvolved
19
Dec 9, 2012 09:15 PM
Gary@MellonRacing
Nov 12, 2008 05:43 AM
dave3kgt
Feb 4, 2007 09:08 PM
