timing belt failed prematurely
Old Nov 2, 2023, 10:30 AM
JamieEVO8's Avatar
shifted at 5000rpm and it was done...belts only like 2 and a half years old with barely 49000km on it
shop suspects that the balance shaft seized
aint gonna be cheap to fix i assume
JoeHKS (Nov 7, 2023)
Old Nov 2, 2023, 12:58 PM
schuhie's Avatar
Nope, its going to be expensive. I had a similar failure where the tensioner failed. In my case it broke the valves off and wrecked the cylinder walls so I ended up pulling it and building the motor.
Good luck and enjoy the eventually stronger engine lol
Old Nov 6, 2023, 12:55 PM
bisha's Avatar
I confirm it will cost you a lot I had the same problem too.
Old Nov 6, 2023, 03:12 PM
ViciousLSD's Avatar
when mine broke around 55k miles, replacing the belts and sensor is all i did
Old Nov 7, 2023, 05:35 AM
schuhie's Avatar
That's pretty lucky. I wish that would have been the case for me lol.
Old Nov 7, 2023, 08:59 AM
ViciousLSD's Avatar
yup super lucky. it broke coming out of a hairpin turn
Old Nov 7, 2023, 01:26 PM
schuhie's Avatar
Crazy. Mine broke deceling at about 10-15mph. Broke 6 valves and messed everything up bad lol.
ViciousLSD (Nov 7, 2023)
lbwilliams44
Sep 20, 2013 03:32 PM
Robertv34
Nov 19, 2011 09:33 PM
Lazyfong
May 1, 2010 12:09 PM
TTP Engineering
17
Jun 27, 2007 01:54 PM
8URVTEC
18
Mar 23, 2006 01:31 PM
Quick Reply: timing belt failed prematurely
