Felpro Oil Pan Gasket
I am only posting this thread for information purposes as I am really curious if this product works.
I am thinking of removing my oil pan to powdercoat as it is really ugly and came across this gasket. Has anyone used this before or have any opinions?
I know the correct method is to use gasket maker to seal it, but if this has good results would anyone recommend it?
I will still go the gasket maker method unless the reviews for this are spectacular, but any opinions are helpful.
I'm currently running this gasket with a brand new oil pan. If you do choose to go to the gasket route, use sealant on the timing and trans side humps to prevent leaks. Also recommend using OE oil pan bolt hardware instead of that hex key dress up hardware.
Racerx9146
Jun 10, 2013 03:25 PM
