baffled oil pan recommendation
Old Nov 17, 2024 | 02:33 AM
JamieEVO8's Avatar
5 Year Member
hi
now im used to the local track and combined with the nankang ar-1 tyre im noticing oil pressure drops in right handers
the moroso pan has a bad reputation for quality and leaking and the infinite evo pan with the external regulator is just over the top
the aeroflow one is bit iffy since it comes across as a alibaba piece
i was thinking going for the JUN/buscher oil pan since they look stock and therefore easy to swap
Old Nov 17, 2024 | 07:46 PM
LetsGetThisDone's Avatar
Race Fab for bolt on install. Infinite Evo for a more involved install, but for oil starve to be 100% resolved.
Old Nov 19, 2024 | 07:07 AM
kyoo's Avatar
Originally Posted by JamieEVO8
hi
get the infinite evo. pretty sure i oil starved my evo even with the racefab.
Old Nov 19, 2024 | 12:40 PM
JamieEVO8's Avatar
5 Year Member
okay, is the external regulator easy to use?
Old Nov 20, 2024 | 07:50 AM
kyoo's Avatar
have a shop do it. set it and forget it. the guy who made the pan is on the boards you can reach out to him to ask questions. thread's here somewhere if you search for it.
Old Dec 11, 2024 | 02:01 AM
TylerAnderson's Avatar
Thank you for explaining.
Old Dec 13, 2024 | 10:25 PM
Tim M's Avatar
5 Year Member
We've got the Racefab installed, but also only 400 miles track miles without issue.
Old Dec 17, 2024 | 09:52 AM
jheff's Avatar
Hope I am not too late on this. I've had the RaceFabNZ pan for a few years on my evo 9 (Some of the previous replies were in on the same group buy). On street tires and at medium and lower power levels (Stock bottom end sub 400whp) it is okay. But after going to sub-200TW tires and sorting the suspension I will see lower pressures (mainly on the octopus corner @ NJMP Thunderbolt which is known for popping 4G63s). Pushing up the power numbers and Cornering G you can see "acceptable" pressure from the RaceFab unit. For a built motor the infinite pan is worth the install hassle.
For a race prepped wet sump, the infinite evo pan has 2 more baffles over my admittedly older Racefab, as well as the external oil pump feed/pressure regulator. Some say its overkill, I call it R factor or insurance. This is not to knock on the Racefab pan, it is still a superb upgrade over stock (36+ psi minimum ive seen over the years comapred to stock which can drop to the teens). You can go bolt on with a Racefab pan and add accusump later or jump straight into InfiniteEvo pan. I'm not selling my racefab to keep as spare in case, its never given me problems.
Old Dec 17, 2024 | 10:38 AM
kyoo's Avatar
I'm fairly certain I oil starved my last motor with the race fab
Old Dec 17, 2024 | 11:03 AM
jheff's Avatar
I believe you. The logs when my motor went point to elsewhere (HG) but I am not denying that lack of oiling looked to be a factor in bearing wear.
Old Dec 21, 2024 | 02:05 PM
Turtletron's Avatar
5 Year Member
I've been using the racefab/Chad pan for years now with 200tw tires and decent aero with no oil issues
Old Dec 22, 2024 | 09:43 AM
JamieEVO8's Avatar
5 Year Member
thanks for the advice everybody i just purchased the infinte evo pan
lets see how long it takes to get here lol
evo_08
Aug 4, 2008 09:34 PM
RyanM
Oct 27, 2004 08:46 PM
