Help Airtrek 4g63
Old Dec 8, 2024 | 03:48 AM
BoostedPanda603's Avatar
Help Airtrek 4g63
Subject: Help Needed with Water Pump Issue on Fully Built Evo 8
Hi everyone, I’m working on my fully built Evo 8, which is running what I believe to be an Airtrek long block purchased off ebay. Engine was built after. Everything in the build is brand new, but I’m running into an issue with the water pump. I’m currently using a 2.4 Outlander water pump (part number: MD978552), but the hub seems too short, causing the pulley to rub against the Evo 8 timing cover. I’m also using an Evo 8 pulley. Am I using the wrong timing cover or pulley for this setup? Right now, I have a spacer on the pulley to address the clearance issue, but there’s a very slight wobble. I suspect this is causing a small leak.
I’ve seen other Airtrek builds that don’t seem to have this problem, so I’m trying to figure out what I might be doing wrong. I’ll post some photos of the engine from before the full teardown and build. Any advice or insights would be greatly appreciated!
I have read many forums pointing that the outlander water pump which I believe to be the correct one. Am I running into a unique issue or am I missing something here? Thanks in advance for your help!
danfalcas
Feb 18, 2016 03:05 PM
V12KiLLa
Oct 30, 2013 07:45 PM
ssabir22
Apr 11, 2012 12:18 PM
THUB
44
Jan 30, 2012 11:44 AM
Murf
Sep 23, 2010 07:37 AM
