Is this normal?
Old Apr 19, 2004 | 04:15 PM
JaReDbOy's Avatar
Is this normal?
just a question:
for the past few months during the winter, I've always gotten a steady 19-20 psi at WOT. Today while driving home i noticed I could only reach 16-17 at WOT.
Is this because the temp today was pretty hot and humid about 80~. ? and the hotter air is more expanded therefore less volume= less psi?
Or should I be looking into this as something might not be working correctly?
Thanks!
also, the vacumn pressure with no throttle was always about 20. today i noticed it going down as far as 25?? wth?
Old Apr 19, 2004 | 06:38 PM
JaReDbOy's Avatar
65 views and no comments???
any info would be greatly appreciated!
i just took it out, now its dark, and the temp should be cooler.... still only getting 16-17 WOT....
grrr
Old Apr 19, 2004 | 06:52 PM
evotomig's Avatar
For how long have you had the lower boost(16-17 PSI) at WOT??
Since today?
Maybe a bad tank and the ecu is pulling timing and boost?
Your upper intercooler pipe could also be loose. Check that.
Just some wild guesses
Old Apr 19, 2004 | 06:55 PM
Hungbee112's Avatar
try tightening the clamps on your blow off valve and every other clamp that you can find. A lot of them are loose coming from the factory.
Old Apr 19, 2004 | 07:26 PM
JaReDbOy's Avatar
yea.. hmm its hard to say cuz i havent really payed attention to the boost at WOT in a couple days.. i know at least a week ago everything was fine.
but a week we ago my friend and i installed the unorthadox racing underdrive pulley. .i called him up and asked him if he thought that would maybe change something with the ecu resulting in lower boost? but it seems rather unlikely.
yea thanks.. im gonna check all the clamps and see if they are tight.
Old Apr 19, 2004 | 07:35 PM
mifesto's Avatar
maybe you are overheating?
Old Apr 19, 2004 | 07:43 PM
JaReDbOy's Avatar
mmmm.. nah i dont think so.. this is even within the first 5 -10 min of driving.
Old Apr 19, 2004 | 07:56 PM
en1gma19's Avatar
maybe it's just the temperature, this past winter, when temperatures got lower, people saw a mysterious increase in boost......this is probably just the opposite......cold air=dense=more boost...........hot air=sparse=less boost........just a guess
Old Apr 19, 2004 | 08:07 PM
chickenbrest's Avatar
i have no idea, but I feel your pain...nothing worse than getting less boost than you previously got and not knowing why. I got a hole in my Bushur intercooler and had to put the stock one back on and now I can not get over 1.3 bar. I have a manual boost controller set to 1.5 and was pulling that consistently before. I am hoping that when I get the replacement intercooler from Buschur and install it everything will go back to normal.
Good luck...
Old Apr 19, 2004 | 08:09 PM
Invoice EVO's Avatar
Veteran: Air Force
Well you're not alone, took my car to the track last week boosted normal around 19-20. I made sure all the hoses were tightened before the track run. Lately at WOT with the tempertures up I've been getting 18.
Old Apr 19, 2004 | 08:15 PM
992gnt's Avatar
It's the temps. For the same reasons that you get higher boost in the dead of winter and need to adjust the mbc/ebc lower, the warmer temps will lower boost a bit necessitating another boost controller adjustment.
Old Apr 20, 2004 | 06:09 AM
JaReDbOy's Avatar
you know what?
i think it is the temp...this morning it was much cooler and i was able to get 18 almost 19...
i had my car last summer, but didnt have my boost gauge, so i didnt know how much boost i was running.
thanks for ur input
3000GT-GTO
Cobb AccessPORT
34
Aug 17, 2013 02:52 PM
ebp99si
Jul 13, 2012 12:35 PM
rartist
Mar 22, 2011 08:09 AM
drewblueeye
Aug 30, 2007 07:33 AM
o4whtevors
Apr 1, 2005 12:09 AM
