What is this thing on my throttle body?
Old Jan 2, 2026 | 04:49 PM
VWJETTY's Avatar
Was driving my lancer evolution today and noticed i wasn't making boost as efficiently. Got home and did a boost leak test. Turns out this little mechanism on my throttle body is the culprit. I'm not even sure what it is. Can i just take the screw off, put some teflon tape around it and put it back in? Or should I replace the seal instead?
The reason why my throttle body looks different compared to OEM is because it rotated since I'm in running a magnus intake manifold
Old Jan 3, 2026 | 09:13 AM
Boomfist's Avatar
"Wax pellet thermo valve", that's what I got from comments on this video from boostedfilms:
Apparently this will regulate the coolant flowing through the TB
Old Jan 3, 2026 | 08:07 PM
VWJETTY's Avatar
https://youtu.be/XcKF8tvZDLU?si=IgTeWYHrqPe-og8o
thanks i saw that. i took mine apart, which was actually pretty clean but the seal has pretty much fallen apart and cracked upon removal. So I replaced it with a similar one from the harbor freight pack of o-ring seals. Luckily one of them was really close to the size and thickness. Installed it back in there and it seems to be holding up. Will boost leak tomorrow (or day after) whenever it isn't 5 degrees below freezing outside!
pistons4550
Nov 17, 2021 05:36 AM
chad99evo
Feb 15, 2013 06:17 AM
Javier F.
10
Dec 25, 2012 01:01 PM
nobullevovii
15
May 16, 2006 06:27 PM
cirpower
Feb 27, 2005 10:18 PM
