boost leak from throttle body linkage connection
Old Feb 9, 2013 | 10:12 PM
chad99evo's Avatar
I have a minor leak from the throttle body @ the linkage connector. It threw a P0507, I checked boost leak and evap = good
when engine is run the idle slowly rises and/or falls slowly within a couple hundred RPMs over a 30second to 1 minute period.
please tell me I don't have to buy the whole throttle body.... Do I? bc I am not allowed a modified throttle body under NASA rules.
Old Feb 9, 2013 | 10:31 PM
06RedRalli's Avatar
Throttle body shaft seals.
Highly common with the throttle bodies.
Check stm they carry them.
Old Feb 10, 2013 | 03:16 PM
BEKevo's Avatar
x2. Get "mil.spec" while your at it, stronger than OEM. Also, replacing throttle body shaft seals, with mil.spec, will not disqualify you under NASA rules
Old Feb 11, 2013 | 11:52 PM
chad99evo's Avatar
thanks guys.
Old Feb 15, 2013 | 06:17 AM
chad99evo's Avatar
just replaced throttle cable couple months back which had slack from that rubber bushing failing- so it makes sense I would have more wear on the seals and linkage connector with the new cable. I don't disagree they are crap and wear out but just sayin domino effect.
beasters
Dec 31, 2018 10:57 AM
moneyhun89
Sep 16, 2013 03:39 PM
sleeezy
Feb 6, 2011 12:37 PM
evilrs
Automotosports - Illinois
12
Mar 31, 2008 03:45 PM
Mrchams
Jul 19, 2005 07:51 AM
