Got a surprise when I direct wired my V1...
Old Apr 20, 2004 | 12:11 PM
THKFAST's Avatar
Thumbs up Got a surprise when I direct wired my V1...
I tapped into the hot wire in the over head courtesy light for my V1 detector. Discovered it wasn't a switched lead and decided to "live" with turning the power button on and off each time. Well, I got out of car and forgot to turn it off. About an hour later, it hit me & I ran back out to the car to turn it off. When I opened the door, the V1 made the POWER UP sound it always makes when first turned on...turns out our Evo's have some kind of power saver feature that cuts the power to the dome light after like 35 minutes if left on. That was a pleasant surprise! I was pretty sure someone once wrote you couldn't access a good/easy hot lead to mount a V1 or other dectector. Nice!
Old Apr 20, 2004 | 12:23 PM
YellowFever's Avatar
nice find
Old Apr 20, 2004 | 12:28 PM
osunick's Avatar
I am a total car geek, but it's called ETACS (Electronic Timing And Control System), introduced with the Galant Sigma in the 80's, it's basically an ECU that governs the interior functions of the car.
http://www.mitsubishi-motors.com/cor...ty/e/mmcs.html
Old Apr 20, 2004 | 12:42 PM
prowler's Avatar
Very cool!
I REALLY need to wire up my V1, I'm getting sick of the way it looks.
Old Apr 20, 2004 | 02:52 PM
WFO's Avatar
WFO
VI install write up
There is a V1 install write up in the "how to" forum.
Old Apr 20, 2004 | 04:23 PM
webguy330i's Avatar
WFO is right!
It's not too hard and you don't trickle drain your battery/have to fumble with the volume nob.
https://www.evolutionm.net/forums/sh...threadid=75666
Old Apr 20, 2004 | 04:28 PM
iodine23's Avatar
This auto shut-off also happens on the trunk light. I've learned both of these from experience as well, heh.
Old Apr 20, 2004 | 04:49 PM
jemm's Avatar
Late 90's .. my E6 never had ETACS .. I like it... It is kinda cool.
Old Apr 20, 2004 | 05:03 PM
stvbreal's Avatar
It also turns the headlights off too. I got in the car the other day and noticed I left my headlights on looking at the switch on the stearing column. Turned them off and thinking the battery is dead, but it started right up! Cool feature! !
Old Apr 20, 2004 | 08:17 PM
Mitchubishievo's Avatar
Thanks for whoever posted the how to link, always wanted to konw this. Also great to know I wont be screwed if I accidentally leave the lights on .
Old Apr 21, 2004 | 06:42 AM
EVO-Lust-VIII's Avatar
Nice feature.... but... excuse the newbiness... what's a V1?
Old Apr 21, 2004 | 06:49 AM
DoingAnything's Avatar
^^^I believe it a Valentine 1 (radar detector)
Old Apr 21, 2004 | 07:23 AM
OnlineAlias's Avatar
I leave my light switch in the "on" position. They go out when you open the door. Its sort of a poor man's auto headlights...
Old Apr 21, 2004 | 08:22 AM
webguy330i's Avatar
onlinealias, it's no good if you're using a TT (which you SHOULD be doing!! )
I don't know about you guys, but I prefer to have ALL electronics shut down before I take the key out of the ignition/the engine turns off. That means hvac, radio, lights, etc. The only thing running still would be the V1 in my car.
Old Apr 21, 2004 | 08:33 AM
WFO's Avatar
WFO
TT
yeah, I wish there was a work around for the TT issue.
FWIW, If you leave the key in the car, with the lights on......the lights will shut off after the TT shuts the car down.
Not that many people live in an area where that is recommended, but it does work.
