Power steering pump and hose HELP!!
Old May 3, 2004 | 06:31 PM
fr34k's Avatar
HELP!! Power steering pump and hose
Hey anyone broke the power steering hose caused by removing the cam gears cover??
damn i took it off just for fun and it's costing me 1000-1100 bucks just to replace it and the pump too..
the car's still in mitsubishi right now and I told them to leave it first till i ask them to fix it.. cos i think that thats too much for those stuff.....
I'm wondering if the power steering pump is really that weak??
cos once i realized that the hose starts leaking i stopped driving and i was farrrrr away from city.. the tow to the mistu dealer itself costed me 350 bucks.....
and they're gonna charge me 600+ for the pump, 200+ for the hose and the rest labor which totals up to 1027 if i'm not wrong... 200+ bucks for a HOSE??
and how do i check whether the pump is really broken? i guess they're just trying to rip me off......
Any help is greatly appreciated...... thanks people!
close to 1400 bucks just because i removed the cam gears cover.....
dont like that man.... HELP!!!
Old May 3, 2004 | 06:51 PM
jj_008's Avatar
A local guy, who is on the board (HAALN), did the same thing. He did it himself and I believe he paid about $200 bucks for the line. You have to take off a lot of parts to get the thing out. He had to jack up the tranny and motor to get the line out.
Why are they selling you a new pump?
Old May 3, 2004 | 07:49 PM
HAALN's Avatar
Hey... that sucks man! I had the same problem, I had taken off my cover cause in a few days was going to the dyno to play with the cam gear timing. Somehow it moved and was cut.
I found the hose online for about $150 at www.mitsubishiparts.net. You can get the part number from the dealer and then look that part up online. I didn't have to replace the pump as mine was fine. I never lost power steering when I noticed the problem and didn't run the pump dry. Taking out the old hose and installing the new hose wasn't fun. I am suprised they only charge you $200. I wonder how the dealership does it. The hard line that connects to the gearbox is almost impossible to get out. You can get to the bolts to undo but couldn't get the hose out because of the hard line and how it snakes around the engine mount to get to the gearbox. I had to undo 3 motor mounts and jack the engine up. Then it took lots of work to get the line free.
Good luck!
Old May 3, 2004 | 08:09 PM
SinCityEvo's Avatar
Maybe it's because you are from Beverly Hills and you can afford it?
Old May 3, 2004 | 11:49 PM
fr34k's Avatar
but still man.. haha my car was towed to Alhambra.....
1400 just because i removed the stupid cover!!
should have not stupidly removed the cover and use the money to buy some stuff man....
Old Jun 19, 2010 | 06:07 PM
style619s's Avatar
yeah so same thing happened to me ... pretty much worst thing ever had to fix
Old Jun 21, 2010 | 08:39 AM
DarksideZ's Avatar
Holy rapeage batman, you can replace all that yourself with basic tools.
Old Nov 4, 2010 | 06:30 PM
Maliphax's Avatar
FML, in process of doing this fix now. here i was thinking it would be a simple 1-2 hour fix... grrr to stupidity in engineering
Old Nov 6, 2010 | 12:04 PM
Maliphax's Avatar
got it done.
1. removed the brace that runs front to back
2. disconnected the rear motor mount right above the hose
3. tilted motor and TADA!! it came free
total time approx 3.5-4 hrs
Old Nov 9, 2010 | 12:03 AM
azinterrider's Avatar
Id buy a used pump from the forums. Ive even got an extra laying around in my garage. At least that will save you some money. After you do that you could bite the bullet on hose and labor. If you are mechanically inclined you could do it yourself. May even find hose here on forums.
Old Nov 9, 2010 | 12:12 AM
3vil_3VO's Avatar
Dang that sucks. I removed my cam cover also just to check the timing belt. I guess I got lucky. Good thing i'm extra careful when removing something I haven't removed before Good luck by the way.
Old Nov 10, 2010 | 06:53 PM
dotman05's Avatar
reminds me of when my cam gears cut a hole in mine..was not fun..
Old Feb 19, 2012 | 06:08 PM
bubba17's Avatar
lmao mine just did that today looks like i have something to look forward to here in the next couple days
Old Feb 21, 2012 | 07:04 PM
dotman05's Avatar
Ouch!Its extra fun you get to lower the subframe to replace it
I got an extra hose if you need it
Old Feb 21, 2012 | 07:07 PM
BlackonBlack2's Avatar
^You guys do realize this thread was from 2004-2010...
