evo is slow with a/c and full car load.
Old Jun 12, 2004 | 09:25 PM
purecoda's Avatar
i feel your pain. when i have 4 people in my lancer with the a/c on, my car is mad slow. but once everybody piles out and i turn off the compressor... no. wait. still slow.
Old Jun 13, 2004 | 05:01 PM
BMan's Avatar
That happens with most cars. When I had my ECU in my T'bird reflashed, I had it set up to turn off the ac compressor at anything over 1/2 throttle. 15% is a big loss with any amount of power. Adding 500+ pounds is hard on any et. Most guys pull out their back seat for the extra 30 at the strip.
BMan
Old Jun 13, 2004 | 05:07 PM
IE Evo's Avatar
Yeah, Shiv tested my Evo with the air on and it cost about 20 whp from what I remember.
Old Jun 15, 2004 | 12:03 AM
marksae's Avatar
The backseats do no weigh 30 lbs. They weigh at most 15 lbs. Anyway, the EVOs 5th gear sucks. You gotta downshift to 4th and turn the A/C off if you're going to try to run someone. Or you can go take him out through some turns. The EVO will blow the doors off 99% of DSMs through corners.
Old Jun 15, 2004 | 12:16 AM
MalibuJack's Avatar
Wow that sucks, my evo definitely disengages the Compressor at WOT.. Many cars disengage the AC Compressor under load.. Do you think there's an ECU difference? I definitely can tell my AC disengages (it stops blowing cold air and the car wakes up) It seems to happen at about 80% throttle on my car. It is a tunable parameter on most cars that have the ability to have the ECU reprogrammed..
Old Jun 15, 2004 | 09:54 AM
Rob W.'s Avatar
Even with the compressor disengaged, if you're still in an "A/C On" mode (ie. the little light is on, or your in Defrost or Defog modes), on most cars the engine ECU also reduces timing. So yeah, you get more performance at WOT since compressor disengages, but you're still losing power due to the timing shift. The compressor may only take 8-10HP to run... the rest is lost in the engine management adjusting for the load.
Old Jun 15, 2004 | 10:05 AM
KillaSweep's Avatar
I would like to state that the Evo's 5th gear is overdrive...adding 600 lbs and having a the A/C on would even slow down a twin turbo porsche. The Evo's 5th gear sucks because it not geared for power...its geared to save gas.
Old Jun 15, 2004 | 10:17 AM
plokivos's Avatar
you're still in 3rd grade.
Originally Posted by damEvo8
ha ur mom slow
Old Jun 15, 2004 | 12:46 PM
eclipsegs2k1's Avatar
my car definitely feels sluggish when i have the ac on.
Old Jun 15, 2004 | 01:00 PM
marksae's Avatar
Are you expecting to have the same performance w/ the AC on? One thing to check for is intake leaks. If you have any leaks in your IC pipes, it will really show in your off-boost AC performance. I remember when my EVO was new, I could barely tell the AC was on when driving around town.
Old Jun 15, 2004 | 01:03 PM
GOKOU's Avatar
You need to downshift!
AC should not disengage. If it does the calibrations on your ECU or PCM is either set inproperly or the battery voltage is low. If the ECU sense low battery voltage AC,heated seats, defrost, along with other things may shutoff.
MagicManRed
596
Dec 9, 2020 07:59 AM
JO3ymac
Aug 28, 2013 08:53 AM
EVO VIII Chris
60
Sep 16, 2003 09:22 AM
neilboone11
May 17, 2003 05:41 PM
