Evo weight reduction ideas
Old Aug 20, 2004 | 08:16 AM
  #46
Peazoo's Avatar
Originally Posted by MR 600
did u test drive an RS? if u did, please let us know. i am thinking of getting one.
No I haven't since I have an 03. It makes sense to do so since that car has a lot
of the weight reduction ideas already incorporated.
Old Aug 20, 2004 | 09:15 AM
  #47
CBRE's Avatar
Originally Posted by trinydex
the only other thing that other people haven't mentioned is carbon fiber fenders, and there are weight savings from replacing the hood, i don' t know why people say it's pointless the apexi evo saves almost 8 pounds and with a varis hood you can save almost 6. and don't run low on fuel if you're gonna take any turns, the fuel tank is shaped like a saddle and you'll get really bad fuel starve and destroy something.
if you want a list of stuff you can replace (not remove) to save weight
battery, fenders, bumper(s), hood, trunklid, wing, wheels, tires, brakes, coilovers, front strut tower bar, radiator, intercooler piping, exhaust, racing seats, drive shaft, flywheel, pullies (not recommended), and all interior paneling can be replaced with cf pieces from tado. and i think i didn't forget anything.
biggest bangs will be seats, if you actually spend 2gs a seat you can shave 20 pounds per seat. exhaust is at least 20 pounds more if you get ti (keep in mind there are a lot of fake ti systems out there, jic and greddy make the only real ones i know of that aren't japan only). trunk lid will save you almost 15 pounds if you get the best (all american motorsports) but about 10 if you get a varis. replacing the front bumper with a gialla piece will force you to remove a bumper beam so net you about 15 pounds. wheels can save you about 5 pounds a wheel, ce28 in 17x9 is 14.6 pounds a wheel. don't spend money on light wheels and get heavy tires, get some nice rubber (basically don't get heavy falkens). you already did battery and that's a huge one up to 20 pounds. all the other mods are tiny weight savings that will add up, maybe with all the other stuff done that i listed you can shave another 20 pounds. and remember i didn't list anything to remove cept the bumper frame, so there's much more there.
Where do you get a All American Motorsports CF decklid?
Old Jul 12, 2008 | 08:11 AM
  #48
Parikh1234's Avatar
im gutting my car for Track only. Ive taken everything from front seats back down to the bare metal. A couple of questions:
1) If I remove the door panels will the glass be exposed when the window is rolled down? I am eventually going to get lexan windows but for the time being, dont want a window to break.
2) What is there to do from the front seats up? I am going to start taking apart the dash today. Any ideas? Radio unit is going. HVAC will eventually go. Airbags will go once the cage and harnesses are in. Thanks.
P.S. This is for the IX.
Old Jul 12, 2008 | 10:23 PM
  #49
nightwalker's Avatar
I've driven RS' and after driving one, I really changed my mind about owning one. No center armrest, no stereo or speakers, interior sounds kind of tinny and cheap (yes, cheaper than our cars already are) The manual door locks and roll up windows remind me of my 81 toyota corolla.
There are a lot of smart things you can do to lighten the car up.
replacing the stock cast manifold with an aftermarket tubular one will save weight and improve the FRONT/REAR weight distr. The same goes for the o2 housing, and cat/test pipe. Almost all the aftermarket pieces of these parts are much lighter than the stock components.
You can also gut the mesh out of your stock bumper. I was surprised to find so many little brackets, bolts, brackets on top of brackets holding the factory mesh in. I didn't weight it, but I piled everything up and put it in a bag, and it was a good amount of weight.
Replacing the factory metal framed fan with a slim plastic one saves weight.
AMS and Buschur make front crossmember replacements that also save weight in the front.
The spare tire/jack/trunk lining all just make the trunk more roomey and save a ton of weight.
I may go as far as finding bolts that are just as strong as the factory ones but made out of a lighter material. Such as the suspension bolts, seats, undercarriage, etc. If you don't think this is effective, pick up a bucket of bolts.
There's more, I just can't remember it all.
Old Jul 13, 2008 | 04:28 AM
  #50
Parikh1234's Avatar
Do you have a write up or pictures of removing the mesh?
Also a link for the AMS or Buschur crossmember? Thanks.
Old Jul 21, 2008 | 08:25 AM
  #51
Dropspeed's Avatar
I would not remove the mesh..............
Even with the larger holes in the mesh it still protects the intercooler and oil cooler from rocks and road debris.
Old Jul 21, 2008 | 08:37 AM
  #52
dudical26's Avatar
Search around a bit....this stuff has all been covered many times before
https://www.evolutionm.net/forums/sh...ghlight=weight
Old Jul 21, 2008 | 09:58 AM
  #53
FJF's Avatar
FJF
I'd suggest reducing rotating mass first. Lighter wheels and rotors make the car feel significantly lighter and a lot more tossable. Make sure to keep an eye on tire weight. Lighter wheels with heavier tires do more harm than good in this respect.
Old Jul 21, 2008 | 10:02 AM
  #54
neonglh's Avatar
Hood is already aluminum, the CF hood won't be much, if any lighter. CF trunk is nice though, because the stock one is steal. Smaller wheels/tires are HUGE weight savings. Its rotational mass too, which is way more important to free up than static weight.
Old Jul 21, 2008 | 10:14 AM
  #55
Parikh1234's Avatar
i have the IX SE BBS wheels, i dont think I can get much lighter than that. Although I do want to do a BBK upgrade ASAP.
CF Trunk and Doors will be on their way in a couple of weeks when I find a good source.
Old Jul 21, 2008 | 10:40 AM
  #56
moovinfast's Avatar
Does a carbon hood really save that much weight over the stock one? The stock one is pretty light. And for weight basically make it into a RS. Also lighter wheels, and exhaust.
Old Jul 21, 2008 | 11:38 AM
  #57
neonglh's Avatar
No, I just posted that 2 posts ago. The stock hood is aluminum, which is almost no lighter, if at all, than a CF hood made with wet carbon, which ALL after market hoods are. A dry carbon CF hood would be like 1 pound, but no one does dry carbon outside of F1 racing and rich people
Old Jul 21, 2008 | 11:47 AM
  #58
teribble's Avatar
you will feel more in the rotating weight then anything else. i would start with the wheels, flywheel, udp, headers.
Old Jul 21, 2008 | 12:22 PM
  #59
FJF's Avatar
FJF
As examples, RPF1s are ~2lbs lighter in 17x8. Buddy Club makes a wheel that's ~3lbs lighter in a 17x9.
Old Jul 21, 2008 | 12:26 PM
  #60
compscibOi's Avatar
Atkins diet.
Seriously, what are your 1/4 times and what HUGe benefit are you going to gain other than completely gutting your car?
Weight savings - lmao...
