good news, 2.3 stroker under 2K
The main advantage of using a stroker is the increased torque at lower RPM's.. If its built and blueprinted correctly, it should easily rev to 7000+ RPM, however keep in mind since your swinging the weight around, slightly further from the crank centerline, you won't have the same throttle response and max rev's won't be quite as high as a fully built 2 liter motor.. HOWEVER, its really not a big difference with relationship.. and the main difference between a 2.3 and a 2.4 is likely the bore.. but I wouldn't risk overboring a turbocharged engine by too much if you plan on running fairly high boost..
Now, with a balanced and blueprinted motor, built with quality parts, with all the durability goodies, and a good head gasket, you could in theory run 40psi of boost, of course the piston design, wristpin location, fuel, head gasket thickness, will all have a factor on whether or not it will live for very long.. but 25-28psi of boost with good head bolts should be no sweat with a properly assembled stroker.. Keep in mind, even with the smaller stock turbo, you can make 450whp or more if you have the combination dialed in.. the difference is you'd have amazing low-end torque, and almost instant spool..
Originally Posted by 2k4EvoVIII
LOL sorry man. Everywhere i go there you are.haha.. I think we are gonna have twin cars the way its looking. How is the Green, Brown stuff in the over flow treating you..haha.. jk bro! Lets see who gets the stroker kit first now. You got my on the turbo kit!
man the guy today at the gas station made fun of me. He said this is normal lol
some times I do things that don't make @#R#@R#@
I would have to disagree. Just becouse you have a stroker kit does not mean you are going to rev out lower. If you have valtrain work and a reprogrammed ecu to remove your revlimiter or at least up your revlimiter you will be fine. A stroker kit is just changing the bore and stroke of the engine giving its displacement which has nothing to do with your valvtrain. There is a reason the professionals imports guys run stroked engines and are still reving out to 9K-10K. Just my 0.02
It's all about piston speed. given the same type of materials in the rods, crankshaft, and main bearing reinforcement there's no question that a motor revving to 9k rpm with a 100mm stroke is going to be shorter lived than a motor with a 88mm stroke. that's the difference between a stock 2.4L (like in the gallant and lancer ralliart) and the 2.0L.
Computing average piston speed is easy, but not as good as using the rod length to compute piston acceleration. There are good calcuators for this, like the ones here for example: http://www.slowgt.com/Calc2.htm#PistSpeed
Average piston speed in meters/sec is just stroke (inches) x rpm / 1181. 28 m/s is the limit for anything that you wish to live very long and even that is very scary territory. What big money import drag motors do has NOTHING to do with what a street-driven engine on a humble budget should do!
Quick math with the 4G64 and 4G63 both at 9k rpm.
4G64 2.4L, 3.94" (100mm) stroke
3.94x9000/1181 = 30.0 m/s BAD NEWS! That's formula 1 type ****.
4G63 2.0L, 3.46" (88mm) stroke
3.46x9000/1181 = 26.4 m/s
IMO this is pretty high. In a former life I had some pretty hot small block chevies. They just happen to have a 3.48" stroke. 9k rpm in one of those required a pretty exotic bottom end.
Consider the stock piston speed of these vehicles:
Evo 20.5 m/s
S2000 (2.0L) 24.0 m/s
Ferrari 360 23.7 m/s
Honda CBR 929
--look left 22.5 m/sI'm not saying you can't run a 100mm stroke at or beyond 9k rpm. I'm saying that to do so you'd have to machine the **** out of the block and run some ungodly huge rods and super beefy main bearing caps. have you seen a pro dragster's rods? Even then, it's life is measured in hours.
Forget valvetrain. Other than running stiff valvesprings it's not too much of a concern with a DOHC engine with shim under bucket. The bottom end is where something is going to break at 9k. And to keep it from doing so, you need to avoid detonation at all costs and use exotic materials.
Originally Posted by ColinL
I'm sorry but I wouldn't spend my money based on your 2 cents! (long post coming up: cliffnotes-- don't try rev a 2.4L to 9k.)
Evo 20.5 m/s
Honda CBR 929
Evo 20.5 m/s
Honda CBR 929
Nah man, no hate. But you never know who might read something and think, "hey I can do (whatever) with my motor! it said so on EvoM!" This same type of person puts a manual boost controller on an otherwise stock evo, including no gauges, and turns up the knob then wonders what went wrong when the engine is 'making funny noises'.
Hope the info is useful to some of you.
I think a 2.4L with one of the RnR equal length turbo kits would absolutely rock for daily driving, and even better yet, autocross! I don't have the money now, but when I have my car paid off, the extra power at lower RPMS is going to rock!
for anyone out there who is considering this kit, a bit of advice: go on ebay, search for a DSM stroker kit from eagle, email the seller. ALL of those guys are so damn cut throat, you can probably get this kit for more around $1500.
Originally Posted by TheGVR4kid
Shepard = 2.0
Turbotrix = 2.0
Bushnutz = 2.0
RRE = 2.0
Leave the stroker kits for the upstart lipstick and rouge boutique shops.
Turbotrix = 2.0
Bushnutz = 2.0
RRE = 2.0
ME = 91 octane
Stroker = Street.. Thats a good thing for a daily driver.. just don't expect obscene high RPM's.. couple that with a larger turbo (since you now have more exhaust volume to drive it) and you have a killer sleeper setup..
Is there anything wrong with the stock 2.4L crank? Are they cast or forged pieces?
After installing my 264 cams, 3" t.b. & flash, I am a bit disappointed with the "grunt" aspect. There is definetely more power down low than before, but I am now starting my quest to build a 2.4 4G64 motor to get some serious torque for my daily driver.
The car pulls like a rocket & is very strong now up to 7,500, however I dont want to tach my car out to get that power.
