**Video** 3rd gear pull with Hallman MBC and boost gauge
Originally Posted by SterlingEvo
How did you mount your camera there? I've got a great acceleration video from my car of a 4 sec 0-60 run I did, but it was with a webcam, so it only fit the speedo in the view. I really want to get one with the boost/speedo/tach so I can see better where I'm shifting. Incidentally, I played around with tons of different ways to get my video camera to mount and none of them really worked. Also, my boost does essentially the exact same thing, so I think it's just right!
I mounted it with my hands
I hand my right hand on the camera and the steering wheel. The camera was resting on the flat part of the steering wheel.
I don't have a manual boost controller, but I do have the exact same gauge as you along with the WORKS P2 and 3" buschur TB exhaust. Doing the same thing you did in 3rd gear my car actually spikes to about 21psi momentarily then falls to about 18 for a second then climbs back up to about 19/20 all the way to 78000rpm. I think you are fine with your current setup. Also once the car is warmed up my vacuum is around 19.
I actually kinda did something similar with my old 95 Integra GS-R. Just held the video cam on the steering wheel. No passenger needed hehe Have a look if you want. Its only 1.4mb and yes the car was modified otherwise the redline would have only been 8000
http://jcolem3.netfirms.com/images/0100DPR.MPG
LakerRaider
15
Jun 24, 2010 10:59 PM
