Over boost problem?
Old Dec 19, 2010 | 08:19 PM
degin219's Avatar
Over boost problem?
So I just bought my 03 evo 8 a few weeks ago, the car is stock only thing is exhaust cat back, and im having nothing but problems with it. So here is one problem that i am having. I keep getting a back fire/ fuel cut in 3rd gear when i go full throttle. I put a boost gauge in to try and trouble shoot it a little still waiting for my Wideband to come in. Here is a video of a 3rd gear pull, drive 1st and 2nd gear normal then get on it in 3rd all the way. Its full throttle the till i have to shift. Sorry for the bad video. Also i could not find a way to post it here just click the link and it will take you to my video. Thanks for the help.
http://s296.photobucket.com/albums/m...01219-1240.mp4
Old Dec 19, 2010 | 08:23 PM
evo8426's Avatar
Definitely not overboost, but I would suggest getting the car tuned by a reputable tuner and then you shouldn't experience any problems with fuel cut. I'm guessing the car was modded before you owned it and the previous owner removed some of the parts but left the tune he had.
Old Dec 19, 2010 | 08:26 PM
4RETECH's Avatar
kinda crappy video.
Anyway, did you ever change or check your spark plugs and gap them correctly?
Old Dec 19, 2010 | 08:32 PM
degin219's Avatar
Yes I pretty sure the car was built at one point since there was a exhaust temp gauge in the car, well the sensor was still there. Also just a few other things i saw.
Im new to tuning evo's, what is a good tuning software/ecu for evo's?
Old Dec 19, 2010 | 08:37 PM
evo8426's Avatar
stock ecu is very good and no reason to change it out. check out the ecuflash section of this forum, tons and tons of information to read about how to tune an evo and plenty of other things
Old Dec 19, 2010 | 08:41 PM
degin219's Avatar
Originally Posted by 4RETECH
kinda crappy video.
No I didnt I will do it this week.
Old Dec 19, 2010 | 08:43 PM
degin219's Avatar
Hey thanks for the info, also I didnt hit fuel cut I just want to post it because it shows the boost like it wont hold it goes to 19 then drops to about 15ish not sure if thats normal.
Old Dec 19, 2010 | 08:55 PM
sparky's Avatar
Originally Posted by degin219
..... the boost like it wont hold it goes to 19 then drops to about 15ish not sure if thats normal.
You'll need to increase wastegate spring pressure. The WGA is adjustable. And as others have stated....get a tune.
Old Dec 21, 2010 | 10:08 AM
degin219's Avatar
Ok thanks for the help.
Old Dec 21, 2010 | 10:30 AM
b16a2delsol's Avatar
yeah thats terrible mine goes from 20 to 18 by redline. I do have hard pipes and a manual boost controller though.
so hardpipes, 3 port , tune
Old Dec 21, 2010 | 07:46 PM
sparky's Avatar
Does your car have a manual boost controller or is it running the stock boost control setup?
Old Dec 21, 2010 | 11:44 PM
LimitedSlip7's Avatar
Overboost come on. YOu can't haven't too much boost.
Old Dec 22, 2010 | 11:34 PM
degin219's Avatar
As far as I know the car is stock nothing there no boost controller I have not been able to really get into the motor too much, will be doing a full inspection starting tomorrow and fixing everything I see work.
Old Dec 23, 2010 | 02:24 AM
The Storm's Avatar
The stock turbo setup will spike up then start tapering off in the higher rpm range. I'm not sure if it should drop that much. I would definetly take to get a tune or have it checked, if it's been modified and then put back who knows what tune is in it.
degin219
15
Mar 12, 2024 11:52 AM
degin219
Jul 22, 2011 09:38 AM
degin219
May 31, 2011 03:23 AM
degin219
May 7, 2011 04:44 PM
snapb1
Oct 14, 2004 07:32 AM
