boost gauge tap
Old Sep 14, 2004 | 07:18 AM
  #46
bolsen's Avatar
Originally Posted by Fritz
I tapped into the fpr for my boost gauge. I notice on startup that it takes a second to register vacumm, perhaps that is the wait until vaporized fuel it gone function.
I have an autometer boost/vacumm and it seems fairly accurate.
I pull 20 lbs of vacumm at idle.
I can only get boost revving out of gear with the AC on.
I get about 19-20 lbs at wot. I can never see it excactly because the car keeps me busy at 19lbs of boost!
20lbs of vaccum?
Old Sep 14, 2004 | 07:20 AM
  #47
siantjab's Avatar
  #48
modvp's Avatar
I get anywhere between 18-21 mmHg depending on conditions.
Old Sep 14, 2004 | 07:35 AM
  #49
chinto's Avatar
Originally Posted by titaniumkingpin
how much do those autometer boost/vacumm gauges go for?
i want to see what i idle at during idle.
i got mine for bout 50 60 bucks
Old Sep 14, 2004 | 10:59 AM
  #50
titaniumkingpin's Avatar
if i buy a autometer that is vacumm/boost.....do i need to tap into any other hoses? or....is it exactly the same setup as my boost only autometer?
Old Sep 14, 2004 | 01:00 PM
  #51
4ce fed's Avatar
No, you can use the same hose.
Old Sep 14, 2004 | 01:04 PM
  #52
chinto's Avatar
try to tap into each line only once so you dont have 2 T's next to each other. if you need an example let me know ill throw up a nother pic. thats if ur haveing more then one boost guage if ur takeing the one out forget what i said.
Old Sep 14, 2004 | 02:13 PM
  #53
yea, im taking one out. i shouldn't need to tap anything then ...right?
Old Sep 14, 2004 | 02:16 PM
  #54
chinto's Avatar
correct if ur takeing it out and just putting a nother one in it installs the same with the vacume line.
mykep83
Jul 9, 2016 09:29 AM
jcsbanks
Feb 11, 2008 11:19 AM
Evo_Bill
Jun 6, 2006 08:50 PM
Kwman
Feb 28, 2005 05:13 PM
dEdiYT11
Oct 30, 2004 05:38 PM
