Keyless Remote Programming
Old Jan 2, 2010 | 08:38 AM
  #31
fwd_josh's Avatar
i grounded pins #1 and #4 and this worked for me on my 04 USDM 8. you have to have the key in the ignition but not on. key in the OFF position, i repeat. and then press the hazard 6 times in 10 seconds, doors will unlock and lock. then press the lock button on the remote twice and it should work.
Old Jan 3, 2010 | 03:07 PM
  #32
!JonZap!'s Avatar
did exactly that but the doors wont lock and unlock.
is there any other way to program a remote key?
Old Jan 3, 2010 | 03:13 PM
  #33
Z_Lancer_Man's Avatar
Could this be an instance where the USDM ECU is different than the AUDM ECU?
Old Jan 3, 2010 | 07:17 PM
  #34
!JonZap!'s Avatar
sorry, the car is a JDM 7
Old Jan 3, 2010 | 08:39 PM
  #35
That's probably the reason why this hasn't worked. I know that this procedure worked for my USDM IX. Good luck!
Old Jan 4, 2010 | 02:46 AM
  #36
!JonZap!'s Avatar
i would agree with that but a week prior to me trying, we did my friends key hence i am hoping someone has had a similar problem to mine.
Old Apr 27, 2010 | 05:24 PM
  #37
tboboy's Avatar
Wow, this worked for me. Ive bought my car and the remote was not working. Ive used the key for a few months and stumbled up on this thread. Now I enjoy keyless entry. Btw- doors do not have to be closed.
Old May 21, 2010 | 10:54 AM
  #38
adorkableVo's Avatar
I've tried doing this.. I got the remote to lock n unlock during the programming process, but when I take my key out, the remote still doesn't work.. Anyone has any ideas?
Old Aug 24, 2010 | 10:41 AM
  #39
ptakats's Avatar
does anyone know the procedure for the evo x? i tried this one and it doesnt work
Old Dec 3, 2010 | 07:17 PM
  #40
powersteer's Avatar
does this works for the X?
Old Jan 29, 2011 | 04:45 AM
  #41
Butt Dyno's Avatar
From: Why do they always call the Evo the Dark Side?
Thanks for this - I bought a car with no remote, then bought a cheap remote from http://www.keylessentryonline.com/ and followed the instructions here. I just followed this advice:
You can just use a short jumper wire to connect Pin 1 to Pin 4 instead.
And now... remote!
Old May 12, 2011 | 05:43 PM
  #42
Turboshrek's Avatar
And now... remote!
My one remote is cracked so its time to buy new ones. Going to buy two from keylessentryonline (above), where can I get new keys from? Do they have to be anything special?
Thanks
Old May 12, 2011 | 05:56 PM
  #43
erald01's Avatar
you dont have to buy the whole remote, if the case is cracked just buy a different case from ebay, i bought mine for $10 shipped. Swap everything from the old remote to the new case for 1 min. They also send you new buttons too.
Old May 12, 2011 | 09:14 PM
  #44
timmiii's Avatar
I would like to thank Z Lancer Man for posting his key fob programming procedure, here it is again just for reference:
1) Insert key and turn to first position (ACC)
2) Jump pins 1 and 4 on the OBD-II connector
3) ** Here is the key - immediately after jumping the two pins, press the Hazard Light Switch 6 times within 10 seconds.
4) The doors will lock and unlock, confirming that you are in programming mode
5) Press the Lock button 3 times (once, then two more times) on the first remote to program
6) The doors will lock and unlock again, confirming the successful programming of the remote.
7) Repeat step 5 for all other remotes, up to 4.
8) To exit Programming mode, do one of the following:
a) Turn the key to off
b) Remove the key
c) Remove the jumper wire
d) Do nothing for 1 minute
9) After exiting programming mode, its always a good idea to test out the remote to ensure the doors lock and unlock as commanded.
Note: Once you enter programming mode, all previously programmed remotes will be erased, so be sure to reprogram all the remotes you would like to use, up to 4.
Note: The driver door does not need to be closed.
Note: If a remote is not programmed within 1 minute of the doors locking and unlocking, the car will exit programming mode, and all remotes will remain erased.
I just used this procedure to program my key fobs on my 06' IX MR with a new ETACS, I've tried the previous methods of just sticking the key into the key cylinder while leaving it in the OFF position however it didn't work for me. I didn't ground pin 1 to the chassis, I connected it to pin 4 which is also ground but in the connector itself while using like someone mentioned before a piece of 18 gauge wire that I got from radioshack a while ago. I was able to do this with the driver's door open.
Old May 22, 2011 | 07:01 PM
  #45
!JonZap!'s Avatar
My key programming issue was caused by the previous owner in Japan, they had cut a wire which disabled a few JDM remote functions including programming. They also ground out the key lock number off the key so that nobody could copy the key code easily.
