Lower Intercooler Pipe install
Old Dec 1, 2004 | 08:12 PM
EVO8LTW's Avatar
When I installed and uninstalled the dump pipe from my old Buschur FMIC I just used a regular Craftsman 3/8" socket, a wobble and extensions and had no trouble with those bolts. I'm surprised that you and the professional shops had so much trouble.
Old Dec 2, 2004 | 01:58 PM
SterlingEvo's Avatar
Originally Posted by zstryder
Did you have trouble with the dump pipe at all? I had loads of trouble with it. Couldn't reach it, socket wasn't small enough, etc... crazy.
I just did this last night! Those bolts were the biggest pain in the buns-hole. It took us a lot of tries (with the elbow joint) and finally got it. The part that REALLY sucked is we finally got in back on, and realized that we left the gasket off So we had to take it back apart and do it again. In the end, it was a pretty tough install (I'll post pics soon), but then again this is really the first thing I've done by myself on the car, so account for that.
Here's a pic of the worst bolt. The piping on either side make the opening just barely to small
Old Dec 2, 2004 | 02:02 PM
Note: I'm sure this would have been MUCH easier had I taken off the front bumper and stuff!
Old Dec 2, 2004 | 02:25 PM
zstryder's Avatar
Yup. I had my front bumper off and everything too (but that's cause my IC came with the lower IC piping... ).
That bolt was a PITA! And to imagine, the aftermarket pipe I put back on there was thicker than the stock pipe.. even less clearance than before! Cross threading that bolt was the most costly mistake I have made yet while working on this car.
Old Dec 2, 2004 | 02:37 PM
mikesevo8's Avatar
With the AMS lower pipe you don't need to remove the dump tube from the turbo.
The replacement pipes go from that pipe to the IC.
Old Dec 2, 2004 | 02:42 PM
mikesevo8's Avatar
Originally Posted by M3lachsilber
Are pics of this job available by chance?
I would like to sticky it..
Here are 2 pics from my install.
https://www.evolutionm.net/forums/at...chmentid=45821
https://www.evolutionm.net/forums/at...chmentid=45822
Old Dec 2, 2004 | 04:21 PM
EVO8LTW's Avatar
If someone is really having a tough time reaching those bolts, you can always drop the starter to open up access, but it really shouldn't be necessary.
Old Dec 17, 2004 | 09:26 AM
Cirrusly Evolvd's Avatar
Sorry, I was an idiot and forgot my camera the day I did the install. Pictures aren't really needed as any monkey with a wrench should be able to do this job.
Old Dec 17, 2004 | 10:13 AM
that's true... I did it
Old Dec 19, 2004 | 10:28 PM
sleet's Avatar
Is that the AMS front-mount too?
Cajun Power
69
Oct 17, 2015 12:52 PM
sabastian458
Dec 11, 2008 12:31 PM
bruce988jl
04-06 Lancer Ralliart How To Requests / Questions / Tips
Jul 23, 2008 02:24 PM
RUFRIDR
Nov 9, 2007 09:43 PM
webguy330i
35
Aug 19, 2004 06:09 PM
