Installation of Blow off Valve
Old Dec 12, 2004 | 05:12 AM
Osiris1012's Avatar
Question Installation of Blow off Valve
Hey guys, I was wondering how hard it was to install a BOV. Also whats a good BOV to get? Does installing an aftermarket BOV void the mitsu warrenty (im guessing yes). I saw a link for a how to installation but the actuall link was broken. Anyhow I dont really plan on upping the boost too much but would still like the good ol swooshing sound that comes with turbo cars.
BOV
This is the one I was looking at, seems simple enough anyone heard anything about this model?
Thanks in advance
Old Dec 12, 2004 | 07:09 AM
GotBoost25psi's Avatar
its super easy it takes like 5 min to do! i guess your not going for sound with that bov right? i love my RFL VTA but i think im switching to GReddy cuz my eclipse sound ruthless with a type s
Old Dec 12, 2004 | 09:05 AM
GreedMOTO's Avatar
An aftermarket air intake will allow the STOCK bov to be heard. If all you want is the satisfying woosh, go that route.
There is no reason to by an aftermarket bov besides the woosh unless your modded. The stock bov holds boost for normal applications, where-as it can leak under higher than stock boost levels. It is also rumored to leak under normal levels too from what I remember.
However, if you have the cash, time, want, need for a BOV, go for it. Install is a breeze as long as you know what you are doing. Remember, some BOV's have a tendancy to exacerbate existing EVO probs like stumbling and stalling due to to much fuel. Run a search and you will see a plethora of info on aftermarket bov's
Good luck and feel free to pm me with some install questions...I have done it a few times.
Old Dec 12, 2004 | 09:09 AM
HoLeeRay's Avatar
From the people I've talked to, the dealership will give you a hard time about a BOV, but it shouldn't void the warranty. I've also heard horror stories on here about otherwise. I think it just depends. I got the Greddy Type S, including the time to do the single-spring mod, it took me about 45 minutes to put in, and that's because I didn't realize that I had to cut one of the hoses to make it fit until I had it in already.
Old Dec 12, 2004 | 09:44 AM
egui42's Avatar
Greddy Type-S with stiffer spring, it is easy to install and holding 21 psi nicely.
Old Dec 12, 2004 | 09:52 AM
OZevoVII's Avatar
the dealership might give ya some grief about an aftermarket BOV, but just keep the stocker for when you gotta take it to the dealership and just swap it back in.
Old Dec 12, 2004 | 06:43 PM
Osiris1012's Avatar
How exactly does the new intake make the BOV louder? (sorry for the newb questions) Do you mean the little wooshing sound that the air intake makes or the actual bov. Thank you very much for your help though, you all have been super great, I can tell this is a good board to be a part of.
Old Dec 12, 2004 | 06:48 PM
GreedMOTO's Avatar
Originally Posted by Osiris1012
How exactly does the new intake make the BOV louder? Do you mean the little wooshing sound that the air intake makes or the actual bov (sorry a little confused about that one). Thank you very much for your help though, you all have been super great, I can tell this is a good board to be a part of.
The stock airbox is not only restrictive to air flow, but restrictive to sound as well.
Reducing the restriction with a new intake will improve hp, fuel economy and let the stock bov be heard. The intake itself amplifies the air induction of the turbo and the turbo itslef is louder, (I know my HKS RS intake is loud as hell).
My aftermarket BOV is recirculated, but still extremely audible. It's not much louder than the stocker was, but it does have a unique pitch.
Old Dec 12, 2004 | 06:52 PM
Osiris1012's Avatar
Talking
Ok now the only question that I now have is how safe is an aftermarket air intake with the air flow cut-outs in the hood. I know with cold air intakes they have to have a valve so that water cant get in the engine so with this car does water stay away from the intake enough? Pretty much has anyone had any problems with that?
Thanks alot bud!
Old Dec 12, 2004 | 07:06 PM
GreedMOTO's Avatar
Thanks alot bud!
You must be referring to the AEM cold air intake with the water bypass valve. Not necessary in our application.
Yes the hood is open, yes water can get in, but not enough to cause problems. Most water would be vaporized on the way in by the heat caused by the turbo. Remember, all you air travels thru the intake, to the turbo, thru the intercooler, back up into the intake plenum and into the motor. Thats a LOOOOOOOONG way to go to cause problems.
I've run an open filter with no probs for a year!
Old Dec 12, 2004 | 07:11 PM
Osiris1012's Avatar
Talking
I run an open filter with no probs in a year!
Yea I failed to think about the air travel though the turbo and what not...im going to be new to turbos.... once this loan goes through that is . Thanks for your patience and help though.
Old Dec 12, 2004 | 08:48 PM
GreedMOTO's Avatar
No prob and welcome to a place where stock EVO's don't stay stock for long!
Old Dec 13, 2004 | 03:11 AM
Osiris1012's Avatar
Unhappy
Hah between the insurance, payments and threat of losing warrenty I may not be modding for more than 20k miles
Old Dec 13, 2004 | 05:02 PM
GreedMOTO's Avatar
That's what you think...hang out here long enough and you will catch the bug.
Remember, there are things you can do to improve performance, not to mention fuel efficiency, turbo life, etc. and still not void your warrenty.
Old Dec 14, 2004 | 05:13 AM
Osiris1012's Avatar
off topic question but does a Turbo Timer void your warrenty? What are the other little tricks that you speak of? Send me a PM if you want.
