How to: install injectors!
Old Mar 6, 2006 | 03:16 PM
nosnip's Avatar
any pic updates here?
Old Apr 11, 2006 | 11:36 AM
FlipRyder21's Avatar
Wink
pic please pic is woth a thousand words heehee
Old Jun 27, 2006 | 10:44 PM
kduncan01's Avatar
Would it be possible to get some pictures?
I am changing fuel rail and injectors this weekend
Old Jul 4, 2006 | 07:06 PM
bernardo's Avatar
Yet another request for pics.... get those suckers back up!!
Old Jul 4, 2006 | 07:26 PM
alfredob1's Avatar
1. Frist clamp down the main fuel hose!
2. Unbolt right side of fuel rail!
3. unbolt FPR side
4. Unbolt fuel rail
5. Pull off the Fuel Rail and the Injectors
6. Unplug the injectors
7. Put injector back > step 6 > step 5 > step 4 > step 3 > step 2 > step 1.
You dont need to do step 2, and 3, but it just makes it a lot easier for me =)
Old Jul 5, 2006 | 12:32 PM
bernardo's Avatar
Awesome, thanks for the pics.
I have some 780cc injectors that will be going in with my 3065 turbo kit, but I'm wondering if I can just install them now. Will the car get too much fuel if I install them before getting tuned, or does the ECU only flow as much fuel as needed?
Old Jul 5, 2006 | 12:38 PM
justchil's Avatar
Don't forget to put some oil on your o-rings! You may go with reusing the stock orings... or you might get owned like I did.
You might want to wait til ur tune date. My car BARLEY made it up on the dyno after the injector install (780's) before it was tuned.
Old Jul 6, 2006 | 12:03 AM
Matz's Avatar
I would definitely hold off, unless you have a way to tweak the ECU settings yourself. The ECU has no idea how to automatically compensate for higher-flow injectors. I'll be dealing with this very problem soon, once I put in my 720s. I will most likely hope for the best and change the injector setting in the ECU and see what the AFRs look like afterward.
Old Jul 10, 2006 | 04:38 PM
500whp.com's Avatar
pictures back up!!!
Old Aug 24, 2006 | 04:47 PM
Blue Evo 8's Avatar
I screwed up by forgetting to coat the rubber o-rings with oil, which caused the o-ring to break and leak gas on 2 occasions
Old Aug 24, 2006 | 10:37 PM
Matz's Avatar
My how to on NCE
Hey guys, just thought I'd post the how-to I wrote on NCE. The tutorial here was a huge help! I just took more pictures and went into a little more detail.
http://www.norcalevo.net/index.php?o...&topic=11710.0
Old Sep 10, 2006 | 06:02 AM
EVOtagger's Avatar
Originally Posted by EvilBlueEvo8
what i would also add to these instructions is before you start this, take out the rear seat bottom. unbolt the cover to the fuel pump. unplug the wiring harness. start the car and let it run the fuel out of the lines. then plug the harness back in, put the cover back on, and the seat back in. this way you have little to no fuel pressure/fuel itself in the lines when you do the rest of this mod.
cant you just remove the fuse for the fuel pump?
Old Mar 12, 2007 | 03:04 PM
EVO8904's Avatar
Originally Posted by gestalt
Just a quick tip. Do not loose those metal U clips. You can not buy them from Mitsu. without purchasing the entire wiring harness for the car.
I just installed my injectors and I lost a U clip, BUT I made another one out of a paper clip....
Old Apr 3, 2007 | 12:21 PM
Redline06's Avatar
So pretty much if a throw some 1000cc in there without tune.. i wont get far.. uhmm.. lloks like that's something ama have to do at the damn shop itself.. am trying to avoid labor charges here ppl.
Old Apr 3, 2007 | 12:41 PM
elhalisf's Avatar
do you have the tactrix cable?
you can temp. change the injector scaling from your stock injectors, 513, to about 850. that should get you there normally.
