How to: install injectors!
Ok, I just did this. I feel there are way too many steps being taken here. You really only need to remove 2 bolts. There is almost no pressure in the fuel lines
Step 1: Remove clips and unplug the injectors.
Step 2: Unbolt the fuel rail (2 bolts).
Step 3: Lift rail and injectors away from intake manifold and swap in new ones.
Now reverse.
Now reverse.
Anyways, I was doing a boost leak test and air just leaks out of my seals. I took the seals out, cleaned them, lubed them with motor oil, and re-installed them. It still leaks air from there, although I minimized it somewhat. So I found these FIC injector seals in hopes they provide a tighter fit. Has anyone tried them out?
I used this process and it worked like a charm!
antics22
Evo X How Tos / Installations
267
Dec 6, 2016 08:40 AM
500whp.com
87
May 31, 2016 01:30 PM
500whp.com
Evo 'For Sale' Exterior Styling
Nov 26, 2007 03:05 AM
