How To: Change your Brake lines
Old Jul 18, 2009 | 10:14 PM
Thoe99's Avatar
Originally Posted by lemmonhead
what is the benefit of doing this over leaving stock?
and nice pics by the way, good job.
Over the weekend I did my first time attack on a small road course. 5 laps per session @70mph tops. Within the first 5 laps, I was already experiencing brake fade and then as I got back to the parking lot, the brake pedal was mushy. My buddy recorded my laps, seeing my rotors glow red and sparks flying out of the front brakes, like an angle grinder going at it. Apparently, at extreme temperatures exhibited at time attacks, the fluid can boil and can make the stock rubber lines expand, causing this mushy pedal.
Old Jul 18, 2009 | 10:39 PM
Tahoe55's Avatar
Sounds like time for brake upgrades. Are your brembos "brownbos" yet?
Consider Motul 600 high temp fluid, even then you will want to bleed after every high temp event. It keeps the fluid clean and ready.
Club racing pads are also a great investment. Ferodo D2500 pads will give you great stopping power without as much rotor wear or squealing as Hawk HP+.
Another great upgrade is a set of titanium shims from Girodisc. They help with the heat absorbed by the caliper
Old Jul 18, 2009 | 10:54 PM
Thoe99's Avatar
Haha, they instantly turned brown in that one event. I was pretty amazed at how much my car's braking system was not ready for a simple road course event yet.
Old Dec 19, 2022 | 01:02 AM
Antini44's Avatar
Originally Posted by Alacris
Quick lesson learned here: I started to do this Saturday and you need a flare nut wrench, 10mm. A regular 10mm wrench will strip the hard line connection if it stuck (and mine was). I even tried liquid wrench with no luck. So I went out and got the flare nut wrench, but haven't had a chance to try again.
Also, use 3/16" clear tubing (Home Depot, Lowes, etc) for a catch can. I drilled a 5/16" hole in the cap of a water bottle and poked an air hole next to it in the cap. Put the line in the big hole (very tight fit) and you're done. Fits over the bleed nipple very tight.
AC
SOS
I have also rounded the bolt on mine, how did you go about replacing the nut?
500whp.com
87
May 31, 2016 01:30 PM
Deca Auto
123
Feb 10, 2013 02:45 PM
500whp.com
66
Apr 30, 2012 06:22 AM
stockEVO_8
Oct 25, 2008 03:23 PM
500whp.com
Apr 30, 2008 02:36 PM
