How to remove / replace your spark plugs
Old Jan 17, 2005 | 07:19 PM
evoego's Avatar
Registered User
I disagree with the gap of .028 to .031, more like .025 to .028. do your plugs a favor, this is helping to foul them out. I run mine at .026
Old Jan 17, 2005 | 07:25 PM
2literturbos's Avatar
anti-sieze yes!
Also I would like to point out that your replacement plugs are not iridum like the stockers. The stock plugs are about $100 from the dealer and maybe $65 strait from Denso or NGK. I replaced mine at 28K and they looked pretty good.
Also be aware that your gap should be .032" or -8 on your part number BPR7ES for pregapped. Chances are if you did not gap those you are at .044" since when I got them for my SR20 and my old turboed B16 thats what they were with out a pregapped p/n. You need to gap them tight to to prevent the spark from breaking up at high boost and high RPM.
You sould have no problem with those plugs as long as they are at the right heat range, which I can't remeber right now.......
The reason iridums are nice is they are suppose to be better at lasting longer, giving a good spark, and resisting fouling.
-James
Old Jan 17, 2005 | 07:31 PM
evo81's Avatar
nice write up.when i was doing my cam install,my plugs looked just as bad.that was around 5,000 miles on the car.i'll probably change them soon.
Old Jan 17, 2005 | 07:49 PM
Jakeg97's Avatar
Originally Posted by taylor
Is anti-sieze compound on the plug threads not recommended on the evo?
i read that its ok to use , but i have not. i might try it next time when i replace the plugs, but that will depend on how hard it is to remove the used ones.
Old Jan 17, 2005 | 07:52 PM
MitsuJoe's Avatar
i hate to be a stiff although this should be in the how to section and the discussion should be here!
My plugs after 15k looked fine. I gapped my down to .26 and it runs fine. I did not notice any difference with these plugs vs. the stock plugs.
Old Jan 19, 2005 | 07:28 AM
sleet's Avatar
So which are some good plugs to get and when should you be replacing them? I've got almost 15k miles, should I replace them soon?
Old Jan 22, 2005 | 10:49 PM
Jakeg97's Avatar
why not - you might need it. plus its cheap to do
Old Jan 22, 2005 | 11:30 PM
HxllxMan's Avatar
Wow ... Need to check mine.
Thx for the tuto
Old Jan 22, 2005 | 11:39 PM
steveevo8's Avatar
what is this gap you speak of.. and how do you know what the gap is??
Old Jan 23, 2005 | 02:41 AM
HxllxMan's Avatar
Would like to know as well? what gap?
Old Jan 23, 2005 | 10:14 AM
Most-Wanted's Avatar
A nice detailed instruction for beginners. Pretty cool.
Old Jan 23, 2005 | 11:01 AM
Jakeg97's Avatar
Originally Posted by Most-Wanted
Gay post! Shouldn't be driving an EVO and not know how to change plugs. Thanks for nothing and wasting bandwith.
another friendly post toward me i see
Old Jan 23, 2005 | 11:06 AM
evoego's Avatar
Registered User
gap at .26 and use BPR7ES or BPR8ES. 2.25 a piece cant be beat!!
Old Feb 10, 2005 | 02:04 PM
sleet's Avatar
I think i'm going to do this during this weekend. I still don't quiet get that whole gap thing tho.
Old Feb 10, 2005 | 07:33 PM
evoego's Avatar
Registered User
just gap them to .026, trust me you will likey!!PM me if you need the gap thingy explained mechanically. thanks and Happy Tuning!!
