Do I have boost leak? #'s given
Ok, not sure if I have a boost leak...
here's results of my test b/c I have
1. My car is stock.
2. 2nd gear: 16 psi
3. 3rd gear: 17.4 psi
4. 4th gear: 19 psi peak, drop off to 17 psi.
So, do I have a leak?
if so, how what should it look like 2nd tru 4th stock?
1. My car is stock.
2. 2nd gear: 16 psi
No leak - maybe. First, all of our cars come with boost taper, meaning it wont hold 19.5psi to redline. Get a Halman MBC - $90 or so shipped to fix this. Secondly, many of our stock BOV's leak - mine does and I haven't bought the MR BOV yet. Other things can leak, but these are the most common. You should be able to hold all except 1.5psi of your peak boost til redline.
as stated above... that is how your ecu is programmed... you will peak ~19=20 psi and then taper to 17... sometimes depending on your car, the boost will taper furthur. you should start to taper @ ~5700-6000... 7000 rpm will be ~ 16 psi.... completely normal for a stock car... once again as stated a boost controller will prevent such a large taper...
guys, just went back 100% to stock, going to get an X. My boost seems really low now im at 4,500' in Reno. max I have been able to hit was 16psi. What up, I dont hear a boost leak. I have a IXSE. Any input would be great.
roidz3
Oct 1, 2015 03:53 PM
DizzyTT
Dec 8, 2004 08:34 PM
