Zeitronix Wideband 02 Install
I have a question about installing the zeitronix egt probe....is it possible to tap a hole in the exhaust manifold while on the car or will too many metal shavings run through the turbo? its just the biggest @$$ pain to remove the manifolds for the 3065 cuz u have to take the turbo off, which means drain the oil and watever else. So is it possible?
Yes, you can if you are very careful. This applies to cast iron manifolds NOT stainless steal ones where shavings make long orange peel spirals.
see
http://www.zeitronix.com/installatio...stallation.htm
Zeitronix Eng
see
Zeitronix Eng
I just submitted a How To and will be posting the pictures shortly....
https://www.evolutionm.net/forums/sh...44#post3919044
kungfugirl
Aug 16, 2011 09:51 AM
dudical26
12
Jul 1, 2009 11:28 AM
jeemybo
Lancer Engine Management / Tuning Forums
17
Aug 24, 2006 08:21 AM
