Quaife Front LSD Install
Old Apr 7, 2005 | 12:26 AM
marksae's Avatar
Originally Posted by DynoFlash
Thanks for the great write up !
Did anyone happen to notice IF it was very hard to spin one front wheel after installing this unit ? I was tuning one front wheel with the car off the air and it had a lot of resisitance and did not feel "right" I did not have a quaife before so I dont know if this is normal or not ? Thanks
I noticed the same thing after I installed mine. I drove my car around for about 10 miles, then jacked up the front and the wheels turned with normal resistance. I'm guessing the stickiness was caused by the fluid not being fully circulated through the diff yet.
Old Apr 14, 2005 | 10:46 AM
Evo8RA's Avatar
Thanks for this great write-up. I used it successfully yesterday. I'm slow and careful so it took me 12 hours, not including deadtime. I did have to "persuade" the CV axle/inner axle combination back in with a few taps with a hammer.
Particular good tip was the info on creating the small slide hammer. My local dealer didn't even have the factory required slide hammer in their shop tool inventory. Marksae's home built model worked like a charm and the inner axles were easily removed.
Old Apr 15, 2005 | 06:20 AM
marksae's Avatar
Okay, so I wasn't the only one who had that issue. I added a note to the install procedure regarding this. I just gave my axle a few good shoves and it popped in.
Old Apr 26, 2005 | 03:02 PM
yesevo's Avatar
u need to screw in and jerk it off on that shaft right?
my mechanic try to push it in instead of taking out....
they hammer it down on that shaft hard for several minutes...stupid mechanic ... you think my shaft, gear all that **** is o.k?
mine drives o.k without any weird sound or anything..
it happend to me when they change my clutch.
Old Apr 27, 2005 | 09:26 AM
EvilBlueEvo8's Avatar
do you have to modify th e transfer case to get this to work (i knew you had to do this; i read it when i read about previous installs of lsd's into non lsd evos)? if not, is this a new drop in lsd?
Old Apr 27, 2005 | 09:37 AM
marksae's Avatar
Nope, no modification needed. The quaife is a straight drop-in replacement.
Old May 1, 2005 | 04:00 PM
timmiii's Avatar
is the quaife lsd the only lsd which will fit into the USDM evo 05'+ transfer case or can other lsd assemblies fit as well?
Old May 1, 2005 | 09:47 PM
AV8NDOC's Avatar
Mark,
nice write-up
how about shimming in the LSD ?? are shims included and is there instructions about this from Quaife?
-D
Old May 1, 2005 | 10:27 PM
marksae's Avatar
Since the whole front diff sits inside the diff carrier, no shimming is required. There are no bearings that get pressed onto the diff.
Changing the diff will not affect the end play of the diff carrier inside the transfer case.
Old Jun 2, 2005 | 05:22 AM
DCSilvrEvo's Avatar
GOD DAMNIT! the fckin Ring Gear bolts are a B!TCH!
Old Jul 27, 2005 | 06:00 AM
Robert_K's Avatar
Subscribe...
Also, how long did the install take?
Old Jul 31, 2005 | 10:37 AM
Evo8RA's Avatar
Originally Posted by 03EvolutionVIII
Subscribe...
Taking my time, I did it in one long day (about 12 hours).
Mark
Old Aug 7, 2005 | 09:49 AM
Robert_K's Avatar
Mark
Thanks! Ordered mine and it should be here this Thursday. Hoping to get it installed this weekend (13th/14th) or the following Saturday (20th). I'll be going to a shop on base that has a lift. That should knock some hrs off. Thanks for the great write up though.
MODS: Think this should get a "Sticky."
Old Aug 9, 2005 | 09:46 PM
evo8usa's Avatar
Originally Posted by marksae
My initial impressions are from my short test drive is that this thing ROCKS. I can actually go WOT through tight turns and the front wheels will keep gripping. Power understeering has been reduced significantly, if not removed completely. I think I actually felt some power OVERsteering on my test drive. Something I've never experienced in my EVO before. I'm scared to really test this thing on public roads, so I plan to bring my car to the next auto-x to really test it.
Question:
What class are you running in in AutoX that will allow you to run the front Diff?
Old Aug 9, 2005 | 10:03 PM
marksae's Avatar
Originally Posted by evo8usa
Question:
I've been running in Street Mod. I'm sure you can run the front LSD in the stock classes since the 04 RS's and all 05s come standard w/ a front LSD.
