Which way does my forge dv valve mount?
Old Apr 22, 2005 | 06:09 PM
BoostWhore's Avatar
just got my forge dv valve not sure which side mounts to the intercooler pipe and which to the intake side. There are no marking or did it come with any instructions. Does the bottom of the piston go to the ic pipe side or to the intake side thanks
Old Apr 22, 2005 | 06:19 PM
WannaRace's Avatar
The side with the nipple should be facing up..
Old Apr 22, 2005 | 09:17 PM
sleet's Avatar
^^ I've got mine the other way Test them both out and see which works best for you.
Old Apr 23, 2005 | 07:46 AM
PVD04's Avatar
The side with the base of the piston should go towards the ic pipe side. If you put it in the other way it will not open.
-Paul
Old Apr 23, 2005 | 07:48 AM
PVD04's Avatar
If you are using stock piping, then you should have it turned the other way so the positive pressure in the intercooler piping helps open the DV, otherwise it will not open between shifts.
-Paul
Old Apr 23, 2005 | 08:44 AM
WannaRace's Avatar
Mine has not failed me yet and is serving its purpose very well. The only time I had it turned the other way was the first time I installed it and it would not open creating a very loud screeching sound (like a choking bird ) I turned it so that the nipple would face up and now I have an awesome DV.
Old Apr 23, 2005 | 08:53 AM
blueo4's Avatar
lets make it simple for everyone:
On all BOV's the opening with the round metal shaft needs to face/directed/connected to the intake (the pipe that the air cleaner/filter is connected to) for recirculation!
The side that you cannot see anything/that is closed by the ring/cap (yes the one you can push open) needs to face/connected to the intake that is going directly to the intake manifold!
Old Apr 23, 2005 | 10:37 AM
BoostWhore's Avatar
Thats what I thought thanks guys
Old Apr 23, 2005 | 10:57 AM
jamevo8's Avatar
I've had mine installed both ways with the stock piping and no problems either way!
xMCxMRx
Oct 7, 2016 07:15 AM
DropThatHammer
May 28, 2014 04:26 PM
Celica2EVO
17
Feb 21, 2009 02:52 PM
rartist
Apr 11, 2008 06:55 PM
justchil
Nov 8, 2006 12:52 PM
