How to Degree Cams?????
Old Apr 27, 2005 | 10:25 PM
woobos's Avatar
Hi
I'm wondering how many of you have actually degreed you cams during install. Also, please advice simplest method of doing it.
Thanks
Old Apr 27, 2005 | 11:14 PM
timzcat's Avatar
Most aftermarket cams now a days are indexed properly so it really is not necessary. Stock is a different story, many are saying they are not indexed right.
Old Apr 28, 2005 | 10:12 AM
woobos's Avatar
cams
Hi
Thanks for the reply..
However, If you wanna degree the cams, how would you do it?
thanks
Ben
Old Apr 28, 2005 | 11:01 AM
Ted B's Avatar
You would need to attach a degree wheel to the crank, and you would need to set up a dial indicator on the #1 cylinder intake and exhaust valves.
You'd then remove the plugs and turn the crank with a breaker bar, noting the valve events as they occur with respect to the degree wheel.
Old Apr 28, 2005 | 05:17 PM
woobos's Avatar
Is there any way of doing this without taking the motor out?
Old Apr 29, 2005 | 06:51 AM
ph2280509's Avatar
Cam gear
To TED B:
This is a question about you 280 cam, if you don't mind.
It was very impressive how you made the adjustment to
improve Torque . Could you explain how you do this? By
adjusting the cam gear only?
Thanks
Old Apr 29, 2005 | 06:52 AM
ph2280509's Avatar
apology
To all:
Sorry about the off topic question.
Old May 3, 2005 | 04:42 PM
Taz's Avatar
Taz
No need to pull the engine out.
Old May 3, 2005 | 10:33 PM
woobos's Avatar
Hi
Can you pls explain how to zero the cams w/o taking the engine out? I was under the impression that you'll have problems fitting the degree wheel.
Thanks
Old May 3, 2005 | 10:34 PM
woobos's Avatar
Originally Posted by ph2280509
To TED B:
Thanks
Thats cool.
I'll like to know too.
Old May 5, 2005 | 05:08 PM
Taz's Avatar
Taz
Hi
Thanks
Don't know the specifics, but all cars down here get zeroed in before cam adjustments and in all cases the crankshaft degree wheel fit in fine. Just need to remove the serpentine belt and tensioner, then the crankshaft bolt with an impact wrench. I can't comment too much as the tuner is very secretive to his procedure and final settings. In fact I don't know where the 0,0 in my cams is at, but I know all cars have different tolerances since he's using similar timmings in the cars and the cam gears rest at different degrees.
-jic
GGevo921
15
Mar 28, 2016 11:00 AM
jbfoco
Jul 6, 2008 01:45 PM
tolga900
10
Jul 4, 2007 08:12 AM
dubbleugly01
Sep 26, 2006 07:30 AM
AMSTuning.com
Mid-Atlantic Region
Feb 12, 2005 08:12 AM
