Walbro 255lph Fuel Pump
Old May 4, 2005 | 06:51 AM
bolsen's Avatar
Another install guide for the Walbro fuel pump.
http://bolsen.homeip.net/fuelpump.htm
Old Jun 2, 2005 | 07:31 AM
vrrrm...psss's Avatar
there are a few things I would add to that install.....such as when you unscrew the black cover, disconnect the harness from the fuel pump, and try to crank the car before undoing any fuel lines........also, on # 8. I would like to emphasize what he is saying about not pulling too hard. I pulled too hard, and the wires came out of the harness, so i put them back to what I thought was correct, reinstalled the pump, tried to start the car, and it wouldnt start. so, I had to remove the pump again, and swap the wires.......it was a very big pain in the *** for no reason
Old Jun 10, 2005 | 09:09 PM
bolsen's Avatar
Thx for the feed back.
Old Jun 19, 2005 | 11:04 AM
BOOSTonHanD's Avatar
sorry to hate on your how to but i found this to have more info.
http://www.evomoto.com/tech_info.php...3_13&tech_id=9
Old Jun 20, 2005 | 03:50 AM
plokivos's Avatar
yeh, that ones good.. but it's easier once you jump on the fuel install first.
Hardest part is, of course getting the metal seal in, which isn't hard as people make it out to be.
it's a simple math.
Old Dec 23, 2005 | 04:48 PM
jbeeker's Avatar
I pulled too hard
Do you recall if the blue wire or the black wire was closer to the release tab? I pulled to hard myself. That could be taken the wrong way
Old Feb 14, 2006 | 02:22 PM
BuLocal's Avatar
I would just like to add, DO NOT DO THIS WITH A FULL TANK OF GAS, I did (the rocket scientist that I am) and it wasnt pretty, gas everywhere.
Old Feb 14, 2006 | 02:24 PM
johnny's Avatar
Registered User
lol ^^
Old Feb 24, 2006 | 10:52 PM
evohang's Avatar
i was wondering if this would be the solution from my car start being able to start up after installing my ExHAUST FLOW....HELP SOMEONE HELP!!!
Old Apr 13, 2006 | 04:55 AM
cij911's Avatar
Type of oil used to set the pump / gasket
The link refers to using a light oil when setting the fuel pump back into the gasket. What type of light oil are people using? Is there a TSB from Mitsu stating what to use? Thanks -- great link btw
Old Apr 14, 2006 | 04:48 AM
cij911's Avatar
Please help w/ light oil used....
bump ++ Please help...
Old Apr 14, 2006 | 07:21 AM
static63's Avatar
When I did my pump I used just a little (just a touch on the tip of your finger) of mobil synthetic. Of course use new oil not old! I have never had a problem!
Old Apr 14, 2006 | 08:09 AM
sleet's Avatar
Make sure you do this with as little gas as possible.
Old Jun 15, 2006 | 01:38 AM
HxllxMan's Avatar
The first time I bought the Walbro pump, nothing came with! Only the pump itself. This is my second Walbro pump and it cames as a kit.
I didn't use the rubber isolator that came with the kit... I used the stock one... is it bad?
Old Aug 30, 2006 | 10:56 AM
andber's Avatar
Anyone?
