How To Install A Taylor Battery Relocation Kit(evo8)
Old Aug 20, 2006 | 01:17 PM
Evo8yurAMG's Avatar
Originally Posted by SMIGS714
So how much does it help to relocate the battery to the trunk?
more room in the engine bay...
if you get the slim battery it frees up alot of space too. but this is the old scool way to do it
Old Sep 1, 2006 | 06:14 AM
phil_deez2's Avatar
Will the OPTIMA red top fit in the original place in the original battery box in the engine compartment....Optimas have about the highest heat tolerance of any battery.
Old Sep 30, 2006 | 07:44 PM
16vEVOIX's Avatar
I can't get enough room on the drivers side or passenger side to mount this battery box. Are you installing this without the trunk carpet panelling? There just isn't enough metal to install this tray in the trunk. I wanted to install it on the passenger side but I would only be able to drill one hole. Did the IX rear tailight house change from the VIII? Did you hammer in the metal taillight housing?
Old Mar 9, 2007 | 11:04 AM
EvoIX2240's Avatar
Another write up I used to help me improve my car. I never said thanks and how much I appreciated the time you put in making this so Thanks!!!
Old Jul 7, 2007 | 02:59 AM
cpoku's Avatar
this was on point and perfect to the "T", had fun working on my car with this guide, thank you very much
Old Jul 14, 2007 | 07:38 PM
badstainless's Avatar
I used this exact kit for my Optima Yellow top! I mounted mine on the right side through the frame rails though.
Old Feb 12, 2008 | 07:45 PM
Inprogress's Avatar
This is a great write up! Thanks a lot!
Old Feb 12, 2008 | 07:50 PM
mitsuboost30's Avatar
Excellent writeup
Old Feb 15, 2008 | 06:15 PM
48mile's Avatar
i've heard that passenger side trunk mounting is better for overall balance because it's opposite the driver and the biased wieght to the drivers side of the vehicle. i'm gong to mount mine soon to make way for a new uicp. thanks for the good write-up and ideas.
Old Feb 17, 2008 | 08:32 AM
EvilBlueEvo8's Avatar
anyone know if you relocate the battery to either corner of the trunk, are you still able to run a trunk cage like the worx or gt?
Old Aug 2, 2008 | 02:50 AM
Shocky's Avatar
great stuff
Old Sep 2, 2008 | 12:47 AM
Dorikun's Avatar
cool.
Old Jan 6, 2009 | 09:31 PM
boostedspra's Avatar
I have gotten my battery relocated and I want to know what size (amperage) inline fuse I should run. I know a starter takes a heck of a lot of amps while it is cranking. So what fuse can I use that would be beneficial if the wire ever ground out but I wouldn't be replacing it everytime I go to start my car?
Old Mar 8, 2009 | 09:00 PM
sslevo's Avatar
Might want to add if you are drag racing at a NHRA track you need a labeled disconnect coming out the back of the car somewhere.
Old Jul 16, 2009 | 03:07 PM
LeXcite's Avatar
Optima is not requiring any type of closed boxes hence it contain absorbed gel ... nothing can evaporate from battery, this type of batteries may be in any position, up side down ... Isn't ?
