how to adjust camber plates?
Old May 17, 2005 | 04:32 PM
spyderx's Avatar
Maybe a dumb question, but how does one adjust camber plates holding the front coilovers? I have Zeal function xs installed and looking to increase my front cambers from -0.5 degree.
Is it simple matter of loosening hex bolts and slide the whole unit inwards for negative camber? If so how much, or how many increments for say additional -1 degree? And does it require much force to slide them?
I then plan to take it back for alignment. The tech only said stock evo front cambers are fixed...
thanks!
Old May 18, 2005 | 04:54 AM
wojo's Avatar
You loosen the 4 hex nuts and then tap it with a rubber head hammer (it should not require much force). Remember, however, that when you change camber settings your toe will change as well.
Old May 18, 2005 | 03:52 PM
spyderx's Avatar
thanks stranger!
Old Oct 6, 2006 | 11:06 AM
M3this's Avatar
From: Where you come to vacation and go home on probation! Vegas!
may sound stupid but how can you tell how much (in dregrees) your moving it over ?
Old Jul 31, 2012 | 07:35 PM
delly86's Avatar
look for the line, when you change that wil not affect your aligement. you can play with it like same as you adjust your coil
QCRVR
Outlander Sport
Oct 4, 2016 02:29 PM
DSMolition
Aug 4, 2016 03:03 PM
subrwho
Sep 10, 2013 10:52 AM
le cow
Driving Techniques
May 10, 2012 09:21 AM
iodine23
Apr 12, 2004 08:55 PM
