help removing the front recaros?
It's just 4 bolts on each seat. 2 on the front, 2 in the back, 14mm if I remember correctly. One of the bolts on the back is underneath the center console so you will have to take that out to get to it. Also, don't forget to unplug the seatbelt wire on the driver's side.
its simple. 4 bolts for the bottom seat braket. remove the plastic cover that covers one bolt thats at the next to the bottom of the pillar. disconect the wire that connects to the stock seat belt plug thingy...(the thing that the seat belt buckles in to.) the disconnection is on the bottom of the seat, near the front tied up to the braket. bam comes out simple as cake!
Of you car take out the bolts that hold the seat to the bracket, then you dont have to remove the center console. There are 4 at each corner, 2 per bracket. They are a Allen Head.
NocturnalEVO
Sep 28, 2017 08:39 AM
think
32
Apr 26, 2005 04:13 PM
