How to change the key ring light on the ignition?
Old Nov 22, 2005 | 11:58 AM
jrsimon27's Avatar
how do i change or fix the light where you put the key to start the car in the ignition?? do i check a fuse or change a bulb?? thanks in advance!
Old Nov 13, 2011 | 12:29 AM
CMoney's Avatar
Bump for an old thread. Anyone know how to replace the bulb?
Old Nov 13, 2011 | 01:31 AM
rodent's Avatar
Take out the three screws in the bottom, pop apart the trim and the bulb is on top of the ignition switch, look for the wire going into the bulb holder (like the one for the cigarette lighter) and unscrew it, pop out and replace with one of the bulbs like for the cigarette lighter. Its a pita to get to and get back in.
Uses #74 bulb. I replaced all mine with red led's from superbrightleds.com
Good info here on other bulbs
https://www.evolutionm.net/forums/ev...light-mod.html
fitch
May 10, 2017 08:21 PM
ScubaStevo
Oct 13, 2016 02:36 PM
daisaw1219
Oct 18, 2010 07:08 PM
Seijuro
Mar 18, 2010 03:09 PM
panda007
Dec 28, 2009 08:02 PM
