Coilover setup help
Old Dec 7, 2005 | 08:40 AM
evilevovegas's Avatar
Coilover setup help
I just installed the Buddy club racing specs and was wondering if there is a general how to on setting them up? Kind of like a step by step for adjusting the camber, toe, etc. Or should I just have them tuned by a pro.
Problem is there are no good shops in vegas. Any idea on how much a good shop like road race charges to allign and adjust them?
Thanks in advance for all the help.
Old Dec 7, 2005 | 09:04 AM
ez's Avatar
ez
Paying someone to do it would be easiest, and may achieve the best results (Road Race Eng for instance).
However, you will not learn much that way. So...if you want to learn to set your car up yourself, then there are numerous books and internet resources out there that will teach you a great deal.
The choice is up to you
Old Dec 7, 2005 | 09:10 AM
SiCKlEyWiKeD's Avatar
you should go with your original idea and drive it off a cliff
Old Dec 7, 2005 | 09:12 AM
I hate you.
Old Dec 7, 2005 | 09:14 AM
you love me biatch
Old Dec 7, 2005 | 09:20 AM
Killboy's Avatar
I would suggest getting a basic alignment first, those coilover probably threw your toe setting out and it will be murder on your tires. Once you get a base setting, you're ready to play with some adjustments.
Old Dec 7, 2005 | 09:33 AM
So get a good allignment and the adjust the camber and height? Or would changing the ride height mess up the allignment.
Old Dec 7, 2005 | 09:42 AM
Killboy's Avatar
Oh yes, adjusting the height will affect the alignment, sorry. I was thinking you had it sitting right and just wanted to play with dampening/preload.
If you don't have a tuning shop nearby, you might just get the height close to what you like, measuring the height on the left and right sides to make sure they are even, then get it aligned. Just don't put off the alignment too long, it may be eating away at your tires.
Old Dec 7, 2005 | 09:53 AM
Ok thanks
Old Dec 7, 2005 | 10:56 AM
djtmotorsports's Avatar
1st: Set ride Height - All 4 Corners
2nd: Set Corner Weight - All 4 Corners
3rd: Set Alignment - All 4 Corners
BTW - I charge alot to align a car
Old Dec 7, 2005 | 11:29 AM
I am new when it comes to this. Corner weight is set by adjusting what? and allignment?
Old Dec 7, 2005 | 11:34 AM
Corner weighting is done on the scales. It is the proper way to balance the weight of the car, front to rear - left to right. Corner weighting is done by moving the lower spring perches - up or down - to move static weight around the car.
Alignment is the camber and caster adjustments.
jameswwt
Jan 16, 2013 02:55 AM
farmeryean
15
Jul 21, 2011 12:59 AM
03BoostedVIII
Northwest Region
Oct 2, 2010 12:04 AM
tmt502
Dec 27, 2007 06:07 PM
