Removing the factory govenor
Old Jan 9, 2006 | 03:28 PM
nosbrody's Avatar
How can i disconnect the govenor from my car? i've heard its right behind the dash and above the pedals, any words on how to?
Old Jan 22, 2006 | 06:39 PM
DanJ's Avatar
I thought it was programmed into the ECU so you would have to either get a stand alone or reflash.
Old Jan 22, 2006 | 06:58 PM
rburris28's Avatar
Are you talking about the rev limiter that is activated when the clutch is in? If so, there is a connector above the clutch pedal that you can disconnect to inactivate it.
If you mean the 155 MPH speed governor, you're going to need a ECU reflash.
Old Jul 18, 2006 | 09:00 PM
bizzarro's Avatar
+1 for evo ix?
Old Jul 18, 2006 | 09:36 PM
Danny23's Avatar
like it was said you need a flash to eliminate the top speed limiter. but if you do that Al can raise your launch limiter thru the flash for whatever you want it set at,(most people go with 6k) or you can disconnect it.search and you will find directions how to unplug it.
Old Jul 19, 2006 | 05:28 AM
16ggst's Avatar
is there a governor on the IX.. when i pulled my image off my ecu it showed max value..
TxFAkuma
Past Winners / Entries
May 13, 2016 02:18 PM
Turbojunkie
Northwest Region
11
Aug 20, 2009 01:22 PM
ArchieBabes
Evo X How Tos / Installations
Nov 13, 2008 09:22 PM
EVONation
17
Jun 24, 2005 09:26 AM
pgmike
Jul 23, 2004 01:42 PM
