Hard Water Spots fix
Well hello again everyone. I am here as your local neighbor hood AUXilary solution to some of your needs. Todays write up (unfortunatly) will be done without pictures for two reasons.
1. It is to hard to Photograph waterspots
2. I cleaned my windows before i took the pictures
So as i eluded to waterspots are the concern of the day. I have posted looking for solutions (no pun intended) to removing the hard water spotsoff my windows. I went to the professionals at Siera Glass (a local company) and they informed me that they would have to replace the galss because it its too hard to get hard water out. To me that sounded to shady so i went on a quest for a solution and finally found one. But first a little history behind some of the products that didn't work. I tried: Amonia, Ajax (which cleans grease off the windows really well, but did nothing for the spots), Armorall glass cleaner, Professional style Autoglass cleaner and CLR. All of these did nothing.
But i finally figured it out. Items you'll need are:
1. Fine grade steel wool ( It must be fine grade so not to damage or scratch your window )
2. Paper towels
3. Some type of window cleaning fluid (ie, windex, glass cleaner, or Armorall glass cleaner)
First spray down the afflicted area rather well, then take the FINE GRADE steel wool and work the hard water spots in circles (you will need some elbow grease.... trust me
). Then take the paper towels and wipe of the window spray residue. After the residue is removed spray down the window and clean it well. Then inspect for spots you have missed and repeat.
Note: Make sure you spray the area down very well as the cleaning solution is the buffer between you scraping your window and getting the spots off. Also be carefull not to rub the hard rubber seal , they may get damaged with excessive rubbing.
2. Paper towels
). Then take the paper towels and wipe of the window spray residue. After the residue is removed spray down the window and clean it well. Then inspect for spots you have missed and repeat.Note: Make sure you spray the area down very well as the cleaning solution is the buffer between you scraping your window and getting the spots off. Also be carefull not to rub the hard rubber seal , they may get damaged with excessive rubbing.
Originally Posted by lbcevo
3M Rubbing compound or swirl mark remover works too.
. I'm not cheap , just money conscious.
Originally Posted by Boltz.
The steel wool for windows is 000 or triple zero. Dont use any other kind or you will scratch your window
Originally Posted by WhatNoise???
I've heard white vinegar will also work. That would be a cheap fix.
makofkalaw
34
Mar 5, 2007 10:31 PM
