defi gauges acting up, need some help
Old Apr 17, 2006 | 01:02 PM
forum04pl's Avatar
so i have defi bf series gauges with the control unit II. i have boost, oil pressure, and egt. when i turn the key on without starting the car the gauges light up like they should and act normal. i then start the car and the gauges sweep like they should then they run. they will work for a little while, about 30 seconds or so, then they will go back to what they look like when the key is on but the car is not started. they dont always work when i start the car either. on a side note my oil pressure is reading really high, like 8.0kpa wich is about 120 psi roughly. something is really wierd here and i cant quite figure it out yet. i hooked up the control unit just like the writeup on project evo on the homepage. any help would be appreciated, a friend of mine is coming to take a second look at it to see if i missed anything.
Old Apr 17, 2006 | 02:29 PM
forum04pl's Avatar
nevermind i found a short
caneman22
May 20, 2015 06:41 AM
bboy_RES
Jan 29, 2008 08:03 AM
dreamevo
Sep 20, 2006 06:50 AM
Joey B
Northwest Region
11
Aug 26, 2005 07:48 PM
GNV Motorsports
Jul 29, 2005 11:55 AM
