MBC Installation Location
Old May 7, 2006 | 11:43 AM
Uncle Boo's Avatar
Where is a good location to install a MBC on a IX? I looked for pictures but didn't come up with any.
It looks like I could use the front lower right bolt that holds the stock airbox down by the headlight plug. It would be a very short run for the lines which I'm guessing is a good thing.
Old May 7, 2006 | 02:19 PM
sleet's Avatar
Try placing it on the battery tie down aswell, I put mine on the T-bolt clamp I have on my UICP.
Old May 10, 2006 | 04:09 PM
heeltoer's Avatar
Didn't install mine but its located underneath the stock airbox on the lower airbox bolt. The location is close to stock and won't raise any suspiciouns
Old May 10, 2006 | 05:28 PM
Mike@Forge's Avatar
It would be easier for us to suggest a location if you could tell us which boost controller you were going to be installing.
Old May 10, 2006 | 05:30 PM
SiCKlEyWiKeD's Avatar
+1
otherwise I would say to put it where you originally wanted to.
Old May 10, 2006 | 05:48 PM
Uncle Boo's Avatar
It's a Forge that came with the Warrtalon package. The side of the box has FMUNOS. I do have a straight and an angled bracket that came with the installation kit.
Old May 10, 2006 | 07:00 PM
Mike@Forge's Avatar
Here is where I first installed these units when we first released them and where many people have done their installs:
It will require that you drill a hole in the straight bracket between the two exsisting smaller holes and you will also need to remove the greenish colored metal hard line for the blow off valve and just run and vacuum line straight from the valve to the intake manifold. The hard line is in the way to install the boost controller in this spot.
Old May 10, 2006 | 07:29 PM
Uncle Boo's Avatar
Thanks!
Old May 10, 2006 | 07:48 PM
DahakaJR's Avatar
I like this spot.
Attached Thumbnails MBC Installation Location-img_0694.jpg   MBC Installation Location-img_0695.jpg
Old May 10, 2006 | 08:57 PM
EVOIX4me's Avatar
that looks funny
Old May 10, 2006 | 08:59 PM
silverEVO8's Avatar
Originally Posted by DahakaJR
I like this spot.
That's where I installed mine when I had it....
Old May 11, 2006 | 11:52 AM
Uncle Boo's Avatar
I went with my original idea, on the front bolt that holds the airbox down. After I had it in place the one line was touching the side of the raditor which was very hot, so I bolted both brackets together to move it away. I could use the factory guides on the bottom of the air intake duct to keep the hoses together for a neat installation.
If I ever get around to buying a digital camera I'll post some shots.
Old May 26, 2006 | 11:12 PM
jmoudry's Avatar
Here's where I put mine:
RedEvoxGSR
Jun 11, 2010 10:37 AM
swandog
Jan 10, 2009 10:57 AM
projekt_shocker
Nov 6, 2006 09:01 PM
silverevo05
19
Feb 16, 2006 01:49 AM
Aux.
Dec 21, 2005 08:45 AM
