fUSE ?
Old Sep 23, 2006 | 02:37 PM
impreza2darksyd's Avatar
fUSE ?
I wanted to switch out dome bulb out for led type light, i guess leds work one way. So, i think i blew out a fuse.. now my radio or any interior lights not workin . besides, climate control, dash lights. I think ive looked at all fuses. anyone have solution, or hidden fuse?
Old Sep 23, 2006 | 02:40 PM
ak47po's Avatar
Same thing here,radio work's but no dome light's.I can't find what fuse it is either,the diagram in the owner's manual dosen't match what's undre the dash.
Old Sep 23, 2006 | 05:15 PM
imajinmyfx's Avatar
open up the fuse box in the engine bay .. theres going to be two 10(red) fuses inside a yellow box.. pull the box up and pull out the fuse
Old Sep 23, 2006 | 05:21 PM
ak47po's Avatar
Those fuse's wont come out.
Old Sep 23, 2006 | 07:35 PM
yes! that worked!.. it was tricky. ak47, just have to unclip sides off of yellow housing.. i just discarded when replaced fuses. thks imajim.
Old Sep 24, 2006 | 12:13 PM
imajinmyfx's Avatar
no prob... when ever you do anything electrical you should alway disconnect the battery so you wont keep blowing fuses
Old May 11, 2011 | 04:53 PM
GuamEVO's Avatar
Can someone chime on this my problem is that the dome light would not come on when I open the doors. I tried the switch on the light set it to door but it still would not turn on when I open the door. I have to switch it to on manually. My car is an 04 RS version. i can see it has the door switches.
Thanks,
Old Jul 13, 2011 | 02:17 PM
hyp36rmax's Avatar
i have this issue the dome light fuse inside the engine bay yellow connector keeps blowing, i've checked the wiring inside the driver side kick panel and still no luck in curing that blowing fuse, i understand i have a short somewhere along that line...
Innesnet
Lancer How Tos / Installations
10
Jan 24, 2018 08:14 PM
TxFAkuma
Jul 20, 2016 02:02 PM
jnsport12
Mar 20, 2014 07:38 PM
detroit pistins
17
Nov 7, 2011 02:53 AM
malonejr2000
Oct 5, 2009 01:03 PM
