GT35 turbo ...intake..MAF... help/ questions
Old Oct 9, 2006 | 04:48 PM
talentsearch301's Avatar
Questions:
here's where Im at...
I cant use AEM
and with MAFTPRO...
No one out here knows how to properly install MAFTPRO
so I plan to just get my ECU flashed
Im trying to use the stock MAF with the GT35 kit and need a custom intake... or do I?
So far I have the coupler 4" reduced to 3" off the turbo....
I have the 3" coupler to connect the intake pipe to the MAF
I need whats in between ... the intake pipe
I need to get one custom made... but I need to let the fabricating shop know what needs to be on there
i.e. valve cover vent tube, air nipple, and Im guessing I dont need the BOV return since Im running the TIAL
would I need something made like this http://evo.dejonpowerhouse.com/
or a pipe that just connect to the MAF
or something like this ...with the bov hole plugged?
http://i2.photobucket.com/albums/y1...er/HPIM0187.jpg
Any sugestions
Any input
Any help will be greatly appreciated
thanks
Old Oct 10, 2006 | 12:25 PM
MalibuJack's Avatar
Call Dejontool for a 4" Intake pipe kit and filter, I used the DSM one and it fit perfectly..
When you call them, just say you need the same one they made for me.
If you plan on retaining the MAF, then you need to use the 3" reducer for the MAF..
Old Oct 10, 2006 | 12:26 PM
MalibuJack's Avatar
If your using a MAF you do need to recirculate, so you may have problems using the TIAL.. The other option is to get the 3" intake pipe from Buschur and use a 3" to 4" coupler..
Old Oct 10, 2006 | 12:28 PM
MalibuJack's Avatar
OOoohhh.. you have a top-mount turbo, I completely forgot about that..
You really just need the coupler and a section of pipe.. It should be really straightforward actually..
Old Oct 10, 2006 | 12:29 PM
Nez136's Avatar
My friend installed a MAF pro last year and it didn't take him long at all, talk to Scott from TTP he can answer any questions you have about the MAFTPRO.
And like Jack said Dejontool is the company to call for misc. intake parts and pipes
Old Oct 10, 2006 | 10:05 PM
TTP Engineering's Avatar
MAFTPro is not that hard. There is detail oriented instructions included with the purchase INCLUDING ECU pinouts, wire colors and directions.
Old Oct 20, 2006 | 09:10 AM
kiddevo's Avatar
Do u remember who u spoke to Dejontool and which dsm 4" intake did u order.
Thanks Trying to get intake for 4" turbo and use maf and valve cover oil breather hose. THANKS
Old Oct 20, 2006 | 10:09 AM
Im in the process of getting the Autronic setup now to help make my life alot simpler
thanks for all the input
Old Oct 20, 2006 | 10:39 AM
MalibuJack's Avatar
I had forgotten to mention that I'm not using a stock MAF, but you can use it with the coupler..
But since I didn't order it with a recirculation fitting or any of the air fittings for the breather and whatnot, I just ordered a 2G Dsm pipe, and flipped it around (so the dejontool sticker was upside-down)
He builds this stuff to order.. so you just have to explain to him that you have an Evo, but you need a 4" intake, and to build it as a 2G DSM intake, but then to put the recirculation fittings on as if it were for an EVO instead.. He's very accomodating.. Then all you'd need is a 4" to 4" coupler for your GT35r, and a 3" to 4" coupler for your MAF.. you may have a tight fit for your air filter if you retain your MAF, so let him know it needs to be about 2-3" shorter because of what you plan on doing.
Old Oct 20, 2006 | 03:44 PM
kiddevo's Avatar
^Thanks for the info
Evoleader88
Aug 11, 2010 06:46 PM
EvoDan2004
May 19, 2008 11:56 PM
TTP Engineering
116
Nov 2, 2007 08:25 PM
KOEvo
69
Feb 1, 2007 03:30 PM
