HKS Turbo Timer Type-0 installed but..
It's not working.
I installed with the HKS harness but, right after I take out my key, the timer shuts
off right away together. I don't know what is wrong.
Please help me out~
Please help me out~
Same thing happened to me. Did you hook up the ebrake wire yet. When I did mine I wired everything then tested it real quick with the ebrake wire plugged in but not spliced to the ebrake wiring and it did not work. I eventually just spliced it for the hell of it and put it all back together and it worked. The timer was reading no signal from the ebrake wire so it would just turn off.
Originally Posted by roy.jovero
This is kinda off topic, but is it really necessary to splice that other wire into the ECU?
i think this is off topic.i'me planning to buy the HKS Turbo Timer Type 1 and install it to my evo 9.is it a plug and play thing or do I need to have a technician to do it? I'me not that good in electronics.what are the things i need to install it? if i'me going to install a aftermarket alarm would it work with the alarm?
FS[West]: hks turbo timer
EVOLUTION9MR
Nov 18, 2014 10:03 AM
