HKS Type 1 Install w/HKS harness...
Old Jun 3, 2003 | 04:33 PM
genimport's Avatar
I have an HKS Type Zero. I know it is similar to the Type 1, but I need to know how I would install it. Is it the same as the type 1?
Please help!!
Tom
Old Jun 3, 2003 | 04:53 PM
Coolguy949's Avatar
Same thing, less wires. It's the exact install minus the two wires that go to the ECU.
Old Jun 3, 2003 | 05:28 PM
genimport's Avatar
Thanks!
Tom
Old Jun 3, 2003 | 07:29 PM
nastea's Avatar
what harness did you use?
Old Jun 3, 2003 | 10:59 PM
genimport's Avatar
HKS MT-6
Old Jun 4, 2003 | 12:08 AM
cky3396's Avatar
there u go
Old Jun 10, 2003 | 11:46 AM
Karash's Avatar
Is that the HKs Type 1 "Black" model? I saw this product on the HKS website but no picture.
Old Jun 10, 2003 | 12:21 PM
Coolguy949's Avatar
Yes.....
Black is US Spec and Silver is Japan/Euro spec (metric measurements).
Old Jun 15, 2003 | 11:34 PM
weightless's Avatar
I'm going to install this timer soon. I just find it strange that you tap into the crank position sensor for rpm, how does it get rpm from that wire? It just seems obvious to tap into the tach signal for rpm.
Old Jun 18, 2003 | 02:48 PM
Boston'sEvO-->8's Avatar
Hey i have the apexi turbo timer if i follow ure directions is it similar??...thanxs
Old Jun 18, 2003 | 05:41 PM
cky3396's Avatar
should be the same if u have a harness.. minus the rpm/speed sensor tapping
Old Jun 18, 2003 | 09:08 PM
thanxs for the info dude!!...i have one more question how did u get the center concell of to get to the ebrake. I tried doing it and it was imposible. Is there a certain way u have to do it for it to come off...thanxs man.
Old Jun 19, 2003 | 02:20 PM
cky3396's Avatar
if i remember correctly,
2 screws inside the armrest cubby hole... pop the intercooler sprayer switch out .. disconnect it and then the whole unit should just come off.
pull UP from the cubby hole
Old Jul 8, 2003 | 02:02 PM
nastea's Avatar
did you tap the blue single wire coming from the E-brake, i tapped it but some reason when i put my ebrake down the car continues to run....
Old Jul 16, 2003 | 01:38 PM
SzuChenEvo's Avatar
has anyone installed the TT inside the armrest cabinet/box? ive seen it done on a supra and it looks very clean...it'll probably be hard to monitor the 0-60 times and such so i'm probably gonna get the Type 0 rather than the Type 1...my question is if anyone has done this, are the harness long enough to do this? pics?
thanks!
