HKS Type 1 Install w/HKS harness...
Do you mind if i ask, how long the wiring option is... Are you limited to about 2 to 6 inches to get it set, or if you extend the wires with crimps, can you customize the layout...
the set of wires that extend to the harness are about 10 - 12 inches long I think and are sheilded together with a black wrapping. The brake, RPM, and speedo wires are about 5 feet long or more.
I just received my turbo timer today and i didn't realize you had to tap into your ecu wires. I'm a bit weary to do this as my car is basically brand new and tapping into the ecu wires would most likely void my warranty. Has anyone had any issues with this turbo timer and warranty ckaims?
edit: Can i just tap into my parking brake wire and not use the other features of my type 1 timer? I'm knocking myself in the head right now. Should have saved money on the type 0 because now i don't think i'm going to be using the added features of the type 1.
Originally Posted by cognisa
on the type -0 u have to hook up the RPM signal wire.what is teh purpose of it.in the instructions it says its optinal
Originally Posted by Deca Auto
Does this work with the stock factory alarm?
Yes, it does work with the factory alarm.
I just installed mine over the weekend. Easy install, just a bit time consuming. Instead of using the connectors that came with the turbo timer I soldered the appropriate wires together. Great write up by the way!
BTW: Did anyone have to calibrate their tubro timer?
I haven't, everything seems to be fine and accurate. Is it necessary to calibrate?
thanks guys
Has anyone mounted under the main dash? .. right under the dash over the ashtray.. ? I'm planning on trying to get it there, but I dont think the wires are going to be long enough.
Thanks!
Thanks!
