HKS Type 1 Install w/HKS harness...
Old Oct 3, 2004 | 08:32 PM
  #61
evo8MR's Avatar
man i bought the type 1, i kind of wish i just got the type 0.........hope my install goes smooth. nice write up
Old Oct 12, 2004 | 07:44 PM
  #62
plokivos's Avatar
You have to ground your wires in order for your Timer to turn on. It'll just beep, if you don't wire it. There is a nut right side of the steering column thats connected to the metal subframe. That's a good place to wire your timer, boost gauge, etc.
The alarm is working fine.
Now, here is the question.
Whenever I have my lights on and the Turbo timer is running and when it shuts itself down, the lights still on.
I can't figure out why. Maybe the door gets open, then close while the engine is running? Is that what you guys are going through too? You have to manually shut your lights off when you leave your car?
thanks
Old Oct 23, 2004 | 07:33 AM
  #63
Fisher22's Avatar
i'm in the process of instlaling my hks type 1. Which wire do you tap for the parking brake? is it the blue one right at the base of it, or is it one of the wire taped together?
Old Oct 24, 2004 | 04:36 AM
  #64
HxllxMan's Avatar
I have a problem with my TT... When on the gauge it shows 1000 rpm, the TT show 1500 rpm... I remember first time it was the speed who was not accurate, now the rpm.
So how you do to make it accurate?
Thx
Old Oct 24, 2004 | 06:19 PM
  #65
Fisher22's Avatar
it should say in the instrictions, but if my memory serves me correct go to the rpm display mode, hit t2, 2000 should flash across the screen, hold the rpms at 2000 and hit t2 again
how accurate are the readings as far as 0-60 and 1/4 mile are concerned?
Old Nov 17, 2004 | 10:18 AM
  #66
boomn29's Avatar
Bump for this question...
Old Nov 19, 2004 | 09:37 AM
  #67
boomn29's Avatar
Originally Posted by Option2
I have a question about tapping into wire#89 In the diagram it shows it as the crank position sensor. I see that #58 is the tach signal. Why didn't you tap into that wire? Excellent write up!!
So the directions are wrong with the timer? It should be #58 and #89??
Old Nov 20, 2004 | 01:02 PM
  #68
Wicked05's Avatar
Thumbs up Great Instructions...
Hey Sky...
got a question for ya....just installed this in my 05 EVO and it went in smooth as heck....
only thing is ....when i tap into #86 Speed sensor (black wire with yellow strips)...i'm not gettin any readings...RPM and everything else works on the car...except for the Speedo feature....
also....on your Black TT Type 1....do your readings show kmh, or mph?....mine shows kmh....
is it because i need to calibrate it first or something for it to show mph?
any help would be greatly appreciated...thanks..
Great instructions....
Wicked
Old Nov 20, 2004 | 01:08 PM
  #69
Wicked05's Avatar
i tapped into #58, and it works fine....i'm just having issues with the Speedo...and my BLACK TT is reading in kph, not mph....
any ideas on what it could be?
Old Nov 20, 2004 | 01:31 PM
  #70
boomn29's Avatar
I didn't use #58, I think the HKS directions are wrong.
You need to tap 86 and 89. Did mine yesterday. Oh, and it shows mph.
Old Nov 20, 2004 | 01:43 PM
  #71
boomn29's Avatar
ECU pic
Check out pic #4
https://www.evolutionm.net/forums/sh...ad.php?t=75668
Old Nov 25, 2004 | 10:25 AM
  #72
Wicked05's Avatar
Talking Finally..thanks
Went to check on my connections...it looks like i didn't snap the 86 Speedo sensor wire down tight enough....
it works good now...
still shows kph...but i was able to set the timer to 'learn' speed sensor pulse width and it works good now...
thanks for the help....
Awesome TT...and it feels good not having to wait in the car for cool-down...
what yr's ur Evo Boom?
Old Nov 28, 2004 | 12:14 PM
  #73
boomn29's Avatar
2003 model; purchased way back in May even! 2nd one in all of St Louis, so I was one of the early, early, early ones.
The mph and rpm's work perfect, including the peak functions - those are really neat. I haven't messed much with the 0-60 or 1/4 mile times yet, but look forward to it. Others??
Old Dec 3, 2004 | 01:08 PM
  #74
boomn29's Avatar
13.21 @ 107mph
Just came back from town, and decided to really test it out. Anyways, I just let out the clutch w/o a lanch and pulled a 13.21 @ 107mph. I think that sounds pretty accurate. I've pulled a 13.0 before and trapped 105mph at the track with less mods (now have complete exhaust and other misc goodies).
Others?
Old Dec 3, 2004 | 01:38 PM
  #75
lancealot72's Avatar
[QUOTE=Wicked05]Hey Sky...
I think you got the UK spec one (KM/H) there is also the US spec one (MPH), i am not sure if you can change it to MPH. You have to order the US spec TT. Not toatally for sure!!
