Ultimate Racing Fuel gauge adaptor
Old Feb 18, 2007 | 07:20 AM
EVO316's Avatar
Hey guys, I was installing my Defi BF fuel pressure gauge yesterday with the Ultimate Racing adaptor. Its' the one that bolts right up to the stock fuel rail. Well it leaks!!! It leaks in the pre-drill/threaded sensor tap, even with teflon tape. I paid nearly 80$ for the adaptor and it doesn't want to stop leaking!!!
Does anyone have any suggestions, or is there a better sensor adaptor that will not leak?
Thanks
Old Feb 18, 2007 | 07:47 AM
EVOllie's Avatar
you dont think you cross treaded it did you?
Old Feb 18, 2007 | 08:00 AM
EVO316's Avatar
no, it actually theaded in very easy. the leak was very small but that was just a idle.
Is there some other type of thread sealant that will work better than the teflon tape?
Old Feb 18, 2007 | 09:30 AM
EVO316's Avatar
bump. anyone? is ther another sensor adaptor? or anything else i can use so it wont leak?
thanks
Old Feb 18, 2007 | 04:34 PM
EVO316's Avatar
evening bump. please need some help
Old Jul 23, 2007 | 09:02 AM
Tha Shocker!'s Avatar
you cross-threaded it....the adapter is for 1/8" NPT and your sensor is 1/8" PT
Old Jul 23, 2007 | 11:53 AM
cpoevo's Avatar
Dont use teflon tape. Use the teflon sealent that comes in the tube you can get from autoparts stores. Clean the threads thouroughly to remove all traces of gasoline. Apply a small amount of sealent and thread the sensor into the adaptor handtight then tighten 1/8-1/4 turn with a wrench. Let the sealent dry overnight and then it will be ready for use. If it still leaks you definitely cross threaded it.
taylorgang
Jul 23, 2011 09:20 PM
Boomba Racing
Sep 30, 2009 07:45 AM
superscout03
Feb 12, 2007 01:42 PM
Enyth
Apr 21, 2006 11:51 PM
EVO MR FU
Nov 15, 2005 05:09 PM
