taking off a stock wing on the evo9 help!!!
Old Mar 1, 2007 | 09:28 PM
EvoRicer's Avatar
All I did was have my brother hold the blow dryer to the area where the Double side tape was, then I gradually pulled on one side at a time until the wing came off. The Trunk will pull up with wing, since there is also a little clip on each side of the wing that clips into a hole in the trunk.
Old Mar 1, 2007 | 09:30 PM
cfdfireman1's Avatar
Why yes I am.
Originally Posted by edwinisdumb15
hahaha are u serious?
wont that mess up the paint?
What did think I meant? Use a hair dryer or heat gun if you can get one.
Old Mar 2, 2007 | 07:43 AM
mtwnind.'s Avatar
Originally Posted by Turbolover
fishing line.
Old Mar 2, 2007 | 07:46 AM
AF-Evo8's Avatar
20lb fishing line works the best, wear leather gloves when you do it also.
Old Mar 3, 2007 | 02:10 AM
Jax419's Avatar
I had a hard time with this too! Im going to try the blow dryer thing once it gets a bit warmer out!
Old Mar 3, 2007 | 12:03 PM
edwinisdumb15's Avatar
thank you so much guys! i was too lazy to get the fishing line cause i think that would of been a bit strong. but the dental floss worked great. i should of pushed up all the tho while going throught it. umm for the evo 9 i dont know about the evo8s theres the bolt section on the front so itll stop it. but there is a plastic one too ill take pics in a little while. but yeah i thought i gotten all of the tape but i didnt know that that was there and ****. but yeah i just took it really easily now its just the process of getting the doubletape out.
can i go without putting the tape or i shouldnt do that?? cuase i wanna put it on and off.
thanks again guys!!!
Old Mar 3, 2007 | 12:19 PM
Old Mar 3, 2007 | 03:23 PM
merkzu's Avatar
On top of helping hold the wing on the tape is kind of a pad between the wing and the trunk.. You might mess up your paint pretty good if you don't use tape, plus you don't want it to go flying off
Old Apr 4, 2007 | 12:44 PM
vietoinkoink's Avatar
I used fishing line, And It worked great!
Old May 19, 2007 | 07:32 AM
Slick-IX's Avatar
i might do this next, i wnat to get a cf trunk and paint it as a spare, but in the meantime ill remove the wing off the stock one\
Ude Lose
Jul 17, 2016 05:53 PM
rm4g3d0n
Jun 21, 2016 09:54 AM
evovin
Aug 29, 2009 10:13 PM
Juan Martinez
Aug 30, 2007 10:25 PM
