Transmission and Transfer Case
Old Jun 23, 2007 | 11:06 PM
bhamEVOguy's Avatar
Originally Posted by J-ROC
what is the grade for each fluid.
u can find all that info in ur service manual
Old Jun 28, 2007 | 02:09 PM
shupadupa's Avatar
You don't need a pump, gravity and patience will prevail, the hardest one to get at is the rear diff, but i hung the funnel up on the garage door and let gravity do it work. Lancershop also has nice How-Tos that i used. Give-er a go.
Transfer Case: http://www.evomoto.com/tech_info.php?tPath=2&tech_id=25
Transmission: http://www.evomoto.com/tech_info.php?tPath=2&tech_id=26
they don't have one for the rear, but it is the same 24mm bolt on the bottom and on the top. Make sure you can get the top off before you drain through the bottom though. Common sense i know, but necessary.
Old Sep 5, 2007 | 12:27 PM
Mr. Evo IX's Avatar
Here is a how to. Most recommend factory fluids for the 6 speed cars.
Old Sep 5, 2007 | 12:44 PM
tvbf1's Avatar
I just got off the phone with Rust at MitsubishiParts.net and I ordered all of my fluids from there.
I got the Mitsu LSD fluid for the TC and LSD, and their MT Fluid for the tranny. I even bought the ACD fluid. The coolant and some poppet fastener for the undertray. I need them because I took the under tray when I changed out my O2 housing and DP.
Here's the parts and price.
Coolant 1 gallon - $16.84
LSD Fluid 1 gallon - $35.05
MT Fluid 1 gallon - $82.36
ACD Fluid 1 quart - $4.42
Poppet Fastener - $1.16 ea
Total is like $163.70 shipped. Someone on here said that the Mitsu tranny fluid works the best compared to BG, Redline, and other. Warraton also agreed. It's recommended that you use nothing but Mitsu fluid for the TC and LSD so that what I'm doing.
I have no idea about the ACD fluid. How often is it suppose to be changed or how to changed it. I think it's to be check and filled if necessary and since it's so cheap, I might as well bought it. Does anyone have any idea?
Old Sep 5, 2007 | 03:29 PM
RussellM's Avatar
Plat Vendor
You called me 'rust' -- Russell --
Its ok though...the southern accent throws off everyone here and they are like 'huh...whu...'.
Thanks again!
Old Sep 6, 2007 | 11:27 AM
tvbf1's Avatar
Thanks again!
Opps, sorry! My bad.
The guys that transfer me over to you said that your name was Rust.
Thanks for helping me though. Damn fluid was hella expensive.
Old Sep 25, 2007 | 09:32 PM
SPANKED's Avatar
Good info, I'm about to change out my tranny fluid. What mileage did everyone do it at and is it bad if I just do the tranny now and tc and diffs later?
slvrevosd
Oct 29, 2015 01:56 PM
THEMEMPHISFORCE
Feb 24, 2009 07:43 PM
daracer18
May 12, 2008 06:55 AM
M5150
Jul 12, 2006 04:23 PM
jdmr2
15
Oct 18, 2004 11:51 PM
