DIY Ground Kit for $20
Old Mar 20, 2004 | 05:30 PM
  #136
bishiboy's Avatar
What are you having problems with. It's pretty straight forward. Connect wire to the points listed. The wire lengths are listed, you just need to strip about 3/4" off each end and crimp on the ring terminals. You can use big plyers, vicegrips or even a vice. Soldering would be even better.
Old Mar 31, 2004 | 01:53 PM
  #137
augi1's Avatar
Originally posted by jemm
Not sure, but for $20 (shipped) more you could get AbWombat's own specifically made for the evo:
https://www.evolutionm.net/forums/sh...threadid=41420
the link to the thread is not working?
is wonbat still selling these or does someone have a link to happy's thread?
I wanted to get these pre-made so all you got to do is install.
Old Mar 31, 2004 | 04:31 PM
  #138
jemm's Avatar
Hi, he is still making them. PM him and I am sure he will set you up with a nice set.. the quality of his kit is said to be EXCELLENT!
Old Apr 7, 2004 | 08:21 AM
  #139
jemm's Avatar
Amp Carrying Capacities of Copper Wire
http://frentzandsons.com/Hardware%20...iesofcoppe.htm
Old Apr 7, 2004 | 10:01 PM
  #140
Turbo Ghost's Avatar
I did not use the bolt on the back of the head as it was too hard to get to, Instead I bolted it on to the rear engine hoist, which is itself connected to the head. I did not ground the tranny.
I am having a very tough time removing the bolt on the back of the rear engine hoist. Would bolting it on to the rear engine hoist work just as good?
Old Apr 8, 2004 | 06:07 AM
  #141
jemm's Avatar
Yep .. just clean it off properly and sand down the area a bit where the bolt will be. Used some good locking washers. Worked like a charm for me!!
in fact in version 2.0 of the kit (more points ... getting rid of the ricey red colour cable) I will still be using this setup!
Old Apr 8, 2004 | 05:53 PM
  #142
SubiEvolved's Avatar
Old Apr 24, 2004 | 12:29 PM
  #143
I installed mine last weekend. I couldn't get the rear engine hoist bolt off so I installed this way (photo attached, sorry about the quality-used my 007 lighter camera for this.)
I don't think I notice anything. My rpm is 800 - 900. When the A/C is on it goes up to 1000 rpm and tapers off back to 800-900 rpm. My headlights does not seem any brighter. My radio isn't any cleaner sounding or louder. Could it be because I installed it on the rear engine hoist?
Old May 2, 2004 | 05:51 AM
  #144
mvm42699's Avatar
From: 85296, 99519, 96817,98310,07306,10461(HomeSweetHome), & 00739
Just installed mine. It took nearly three hours alot tight spaces plus the rear engine hoist bolt was a ***** to get it off. Very akward position to un bolt it. I went with a 4 gauge plus bling bolt on connectors. Don't know if I suppose to notice any performance gain but I notice at idle it's alot smoother....Thanks Bishiboy for posting the specs. Next one I'll do will be probably 8 guage transparent/ gray just to give it the OEM look...best mod for the buck compared to what Mitsu is charging theirs for and probably made in china...
Old May 11, 2004 | 12:45 PM
  #145
jedinite's Avatar
moving to how-to to keep this around
Old May 12, 2004 | 02:41 AM
  #146
AbusiveWombat's Avatar
Yup...I'm still here and still have them. My original thread was removed by the moderators for unregistered vending. Just PM me and I'll hook ya up.
FYI, I package directions with my kit that should cut what normally takes 2-3 hours down to 45 minutes. The kit also includes the transmission bolt.
Old May 15, 2004 | 01:33 AM
  #147
marksae's Avatar
Thumbs up
Yep, I just did mine 300 miles ago and my car definitely feels smoother at idle, especially w/ the AC on. The low end/off-boost power and throttle response was noticeably better. WOT felt about the same, maybe gained 1-2hp. It was definitely well worth the $45 and 4 hours I put into this project. I like how my black ground wires just blends into the background in the engine bay. It looks really stealth.
I used the bling bling gold plated Monster ring terminals w/ black 4 gauge wire. Crimping the connectors onto the wires were somewhat tricky since I didn't have that large of a wire stripper and crimper. I ended up using a razor blade to strip the wire, and a bolt in a vise to crimp the connector.
I also had to take my die grinder and grind down my big fat ring terminals mounting to the battery to get it to mount flush.
Attached Thumbnails DIY Ground Kit for -ringterminal.jpg   DIY Ground Kit for -diyground1.jpg   DIY Ground Kit for -diyground2.jpg
Old May 15, 2004 | 06:22 AM
  #148
nobullevovii's Avatar
Registered User
The install of this was pretty easy. The rear engine is a pain, but it is possible. I took out the battery instead of the intake to get to the tranny. If you forget to buy the tranny bolt, then take a bolt from the coolant overflow resevoir. Also, the cables I had would smell from burning, but after some time that went away.
Old Dec 9, 2009 | 05:57 PM
  #149
F2000Driver's Avatar
I know this post is ancient and I'm digging up old dirt., it's my first post here to ..
Went to the audio shop, paid $25 for quility 4 gauge audio wire & 12 connecters for a $50 total, overspent but I am beyond happy with the outcome..
I have the Cosworth 272 cams and my evo 9 runs sloppy at idle...NOT ANYMORE..
Things I have seen: the ground setup gained 300RPM at idle when under full load of lights, windows being rolled up, u name it..; I cannot stall the car as before with the grounding setup....RPM band is smoother and power seems to be more crisp. Headlights are Incredibly bright now and I cannot wait to uprage my stereo system now...Thanks to all who have posted, its served me well
Old Dec 9, 2009 | 06:02 PM
  #150
I know this thread is ancient and I'm digging up old dirt., it's my first post here to .. recently bought my evo 9 from a guy in town..
Went to the audio shop, paid $25 for quality 4 gauge audio wire & 12 connecters for a $50 total, overspent but I am beyond happy with the outcome..
If Mitsubishi is offering is offering an upgraded ground setup, then isnt this a logical step? I think so.
Things I have seen: the ground setup gained 300RPM at idle when under full load of lights, windows being rolled up, u name it..; I cannot stall the car as before without the grounding setup....RPM band is smoother and power seems to be more crisp. Headlights are Incredibly bright now and I cannot wait to uprage my stereo system now...Thanks to all who have posted, its served me well
